Old 02-06-2010, 12:03 PM   #1
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Removing stock air box tube
I'm trying to remove the stock air box tube, and there's that little plastic breather tube that comes off the left side of the tube and connects to the passenger side valve cover...does that thing just pull off of the valve cover, or is there a trick to it? I don't want to break anything I'm not supposed to...
jachevy28 is offline   Reply With Quote
Old 02-06-2010, 12:53 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There is a clip under there that holds it on. It will come off if you pull it hard enough though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-06-2010, 02:50 PM   #3
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Thanks, got it
Old 02-06-2010, 05:11 PM   #4
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
Yeah, I could never get the clip to release, I ended up just yanking it off! The hardest part for me was removing the stock air box from its 2 mounting brackets with those darn rubber washer/nut clips. those things would not budge!
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
**K&N TYPHOON and AIRCHARGER Intake kits ~ 18+ HP! ~ Lowest Prices!** Circuit Motorsports V8 Bolt-Ons & Tunes 81 05-24-2010 05:21 PM
"New" Air Box Cover zeespeed Cosmetics and Lighting Modification Discussions 2 08-24-2009 01:51 PM
Intake/ Air Cleaner observations and thoughts... (?V6/V8?) radz28 5th Gen Camaro SS LS LT General Discussions 27 01-23-2009 09:14 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
