Old 02-06-2010, 06:30 PM   #1
CGR
Drives: 2010 Camaro
Dyno Run and LS-A Install on CGR/Hankook/Blu808 Camaro
This car is being built to compete in the 2010 Formula Drift championship as well as some select west coast Red Line Time Attack events. We also plan on running Pikes Peak as long as we get the funding to do so.
The car finally got to the dyno last week after almost 3 months of waiting on parts to get in. We are really pleased with how the tune went, Mitch Pederson from MP Tuning did an amazing job getting the motor running perfect. The LS-A motor is stock with the exception of the Hennessey pulley/snout upgrade (takes the motor from 9 to 13 psi of boost). We should have some testing footage of the car in the next couple of weeks.
Here is some info about the car:
2010 Camaro 1SS (vin 32584)
Weight - 3072 lbs (wet)
HP - Enough
TQ - Also enough
Engine
GM Performance LS-A crate motor
AEM engine management
Jordan Innovations wiring harness
Hennessey Performance pulley upgrade
Holley 90MM throttle body
Stainless Works long tube headers
Blu808 blast pipes
Fluidyne radiator
Fluidyne oil cooler
Fluidyne transmission cooler
Fluidyne heat exchanger
Canton Racing Accusump
Aeromotive A-1000 fuel pump and fuel cell
PFADT billet motor mounts
Drive line
Exedy triple plate carbon clutch
Exedy custom flywheel
PST carbon drive shaft
Suspension
Eibach Multi Pro R2 coilovers
Eibach sway bars
Brembo 2 piece rotors
Brembo 6 piston calipers (front)
Wheels and Tires
Forgeline ZX3R 19x11 Rear
Forgeline ZX3R 18x9.5 Front
Hankoook Ventus RS-3 305/30/19 Rear
Hankoook Ventus RS-3 265/35/18 Front
Body work and interior
Seibon Carbon Hood/Trunk/Doors/Fenders
Sparco Evo2 seats
Sparco steering wheel
Sparco quick release
Sparco 6pt harness
Xtreme carbon/carbon dash
AIM Pista dash
Blu808 custom roll cage
Wilwood aluminum pedal assembly
Here is a video of the dyno from last Thursday at Gruppe-S in Lake Forest, CA
Dyno/LS-A Install
CGR is offline   Reply With Quote
Old 02-06-2010, 06:44 PM   #2
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Very nice!!!
Can you post the events you guys are planning on running?
Old 02-07-2010, 11:27 PM   #3
CGR
Drives: 2010 Camaro
Very nice!!!
Formula Drift Pro Championship
Streets of Long Beach - Long Beach, CA - April 9-10
Road Atlanta - Braselton, GA - May 7-8
Wall Speedway - Wall, NJ - June 4-5
Evergreen Speedway - Monroe, WA - July 9-10
Infineon Raceway - Sonoma, CA - August 6-7
Las Vegas Motor Speedway - Las Vegas, NV - August 20-21
Irwindale Speedway - Irwindale, CA - October 9-10
Old 02-07-2010, 11:57 PM   #4
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Old 02-16-2010, 06:28 PM   #5
CGR
Drives: 2010 Camaro
Testing Update:
We still haven't changed the factory steering angle and we need to raise the car a bit to not be on the bump rubbers but overall the car performed great.
Old 02-16-2010, 06:29 PM   #6
CGR
Drives: 2010 Camaro
Testing Update:
run your camaro at the LSX Shootout and earn contingency $$$$ nmcajeff Dragstrip and Launch Techniques Discussion 4 02-09-2010 12:25 PM
LSX Winter Dyno Tuning Specials Starting @ $250 Mike Norris V8 Bolt-Ons & Tunes 5 01-25-2010 10:45 AM
LSX Winter Dyno Tuning Specials Starting @ $250 Mike Norris USA - Great Lakes 1 01-21-2010 09:06 AM
Just drove a new Camaro LS Angrybird 12 5th Gen Camaro SS LS LT General Discussions 6 11-05-2009 04:20 PM
This weeks Camaro Ordering Constraints! 2SSRS@Gen5diy 5th Gen Camaro SS LS LT General Discussions 68 09-17-2009 12:09 PM
