Old 02-06-2010, 07:20 PM   #1
DkknightX
Drives: 2006 Chevrolet Cobalt SS/SC Stage 2
Washing Microfiber Towels
I have a slew of microfiber towels I purchased when I first started using Zaino products, etc. Now all of the towels are dirty and I was wondering if anybody knew any specifics on how to properly wash microfiber towels. It is said that if they are washed, they are softer than when first purchased. What temperature of water should I use? What kind of wash cycle? Permanent Press? How much and what kind of detergent should I use? Should I use a regular tumble dryer to dry the towels or have them air dry? Any information would be extremely helpful! Thank you all kindly in advance!
DkknightX is offline   Reply With Quote
Old 02-06-2010, 07:44 PM   #2
ProstZ28
ProstZ28's Avatar
Drives: 79 Pro Street Z28,2010 2SS RS
im not sure of the water temp but i know wash in normal wash ,tumble dry but do not use any (any) fabric softner at all in the washer or dryer
2010 BLK 2SS RS M6
GM PAINTED GFX PACKAGE
ROTOFAB CAI, MUFFLERS DELETE,
CARBON FIBER LOOK EMBLEM OVERLAYS,
SIDE MARKER & REVERSE LAMP BLACK-OUT
20% TINT ON ALL GLASS EXCEPT W/SHIELD
NL PERFORMANCE DOVETAIL SPOILER,
GM HERITAGE PAINTED GRILLE'
MORE TO COME!!!!
ProstZ28 is offline   Reply With Quote
Old 02-06-2010, 08:30 PM   #3
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I read that when washing them you should use a second rinse cycle. Also, do not use fabric softener in the wash and do not use dryer sheets when drying.
Old 02-06-2010, 09:02 PM   #4
DkknightX
Thanks for the suggestions! Definitely means a lot to me!
Old 02-06-2010, 09:07 PM   #5
Mark A Collier Sr
Retired Army, 101st ABN
Mark A Collier Sr's Avatar
Drives: 2 SS/RS w/sunroof
Just buy a new bag... They are in bags of 15 for $4
"BABY" is a Summit White, 2SS/RS, My Tribute to the 13 years I served in the 101st Airborne Division!!!
ORDERED: 18 JUL 09 #NMMS88,
BORN ON 4 NOV 09 at 12:26pm VIN:63460~ HOME on 18 NOV 09!
"101BABY"
Mark A Collier Sr is offline   Reply With Quote
Old 02-06-2010, 09:15 PM   #6
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
I use permanent press with dawn/detergent mix hot water. I let them soak until the water turns warm (~1hour) then let them go throught the cycle. I turn the dial back to the rinse and let it go from there. Then dry on low w/o a fabric softener. They come out pretty clean unless i ues them to clean the wheels.
Old 02-06-2010, 09:18 PM   #7
Angelo@Autopia
Drives: 2014 Ford Focus ST
While it's true that Microfiber is remarkably strong and can be machine washed using any laundry detergent, commercial linen and laundry services were experiencing a problem. Repeated washings with the strong detergents used to clean shop towels was causing the fibers to stiffen, reducing the towels effectiveness and cleaning ability.
Micro-Restore removes all manner of greasy, oily stains while keeping the individual Microfibers soft and flexible. Cloths, towels, mitts and applicators emerge clean, soft and fluffy, wash after wash.
Micro-Restore is a 100% biodegradable detergent with special water softeners to prevent fiber stiffening. The product contains no bleach or fabric softeners yet will break down heavy grease, motor oils, wax residues and stubborn stains restoring a like-new softness through several hundred washings!
One last note. Micro-Restore will also clean and revitalize cotton towels, natural and synthetic chamois. (Always wash Microfiber products by themselves.)
www.ProperAutoCare.com
800-628-7596
Old 02-06-2010, 09:19 PM   #8
johndawg
I'd rather be shooting...
johndawg's Avatar
Drives: 2010 2SS/RS Black/Black
Send a message via AIM to johndawg
I throw them away and buy more... same for my socks and underwear!
just kidding!
regular wash and dry... NO fabric softner.
Follow Us on
The Official Photographer of the 2010, 2011 & 2012 Camaro5 Fests!!! www.theshuttergroup.com
johndawg is offline   Reply With Quote
Old 02-06-2010, 09:21 PM   #9
Hoddi
Camaro Girl ~
Hoddi's Avatar
Drives: 2010 Camaro
And don't wash them with anything else.
Hoddi is offline   Reply With Quote
Old 02-07-2010, 06:29 AM   #10
IOM-SS
IOM-SS's Avatar
Drives: 2010 SS RS 2G1FT1EWXA9163596
Smile Microfiber
Costco sells Microfiber cloths for $15.00 a bag of 35 thank you everyone for the tips about how to wash them.
IOM-SS is offline   Reply With Quote
Old 02-07-2010, 08:38 AM   #11
Chris@glimmerglass
Drives: 2001 S10, 2002 M3
Send a message via AIM to Chris@glimmerglass
With all due respect to Costco (because I live there nearly everyday!!) I would only use their microfiber towels for clean up in certain areas e.g. door jams, under the hood, trunk jams/shutes, rocker panels, inner fender wells. I learned this from experience. The edges are not sealed and if you accidently rub it the wrong way on your freshly polished or waxed paint, the edges are definitely rough enough to scratch the finish.
Now, I only use a towel that has a satin edge or similar protective liner like silk. For the record, I wash approx 200 mf towels a week and have done so at that rate for nearly 4 yrs now and the only way I have truly cleaned my mf towels was by throwing in 3 ounces of Poorboy's APC. It is biodegradable so safe for washers, etc. It is the only product I trust to break down all the chemicals in the towels, thus removing any discoloration from the polishes, etc. Trust me, if you don't remove it all, you are better off throwing them away. I have learned my lesson, countless times. In addition to the Poorboy's APC, I throw in a couple ounces of MicroRestore. This one, two punch is all you need to completely restore your MF's to new condition. Always use warm water to wash, cold to rinse, a second rinse cycle, and dry on low air dry with no FS. It will prolong the life and safe you a lot of headaches and cash.
Chris@glimmerglass is offline   Reply With Quote
Old 02-07-2010, 03:44 PM   #12
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Here's a good thread
2LTRS is offline   Reply With Quote
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 11:00 PM
Promotion on Microfiber Sponge and Microfiber Mitt SoCal Shop Guy Wash/Wax/Detailing and Cosmetic Maintenance Parts 1 12-01-2009 05:49 PM
Washing with boar's hair or microfiber Yellojacket Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 1 08-19-2009 10:33 PM
Mr Clean Auto Dry & waterblade? Matt'sSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 08-17-2009 01:19 PM
Towels, Applicators, Mitts, Etc..., Tecca Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 22 06-29-2009 03:52 PM
