JEFF2010SSMANUAL
Drives: IOM 2SS/RS LS3 Join Date: Aug 2008
Weird sound in diff or trans. 6sp manual
Once I broke in my 2SS/RS manual I did a few speed shifts, and drove it like a muscle car. A couple days later and ever since I hear a strange noise like a wining sound??? Sounds like the pumkin. At the time I had about 1000 miles. I now have 9600 miles and it still sounds weird. Any ideas ???
I did a SEARCH first with NO results. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Callaway Rogue Join Date: Jul 2009
Did you take it to the dealer?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
A whining sound from the trans is usually something with the synchronizers (sp?). If it's coming from the differential there can only be so much that's wrong. People have been complaining about the stock fluids causing both the diff and trans to be pretty noisy. If everything is in good working order (gwo) then you might think about a fluid change.
#4 | |
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
Additive is not needed if you're using RP as it is already in their oil.
#6 |
JEFF2010SSMANUAL
Thanks people. I really don't beat on it. I bought it on Sept 12, 2009, broke it in, and had some fun maybe 10 times I really got on it, but NOTHING compared to the MASSIVE BEATING'S I gave my Civic Si and 300HP 06 modded TL manual. I put snowtires on it around Nov 20, 09 and CAN'T beat it, or I would MELT my expensive HR Blizzak's. I guess I will take it to the dealer and see what they say after a test drive.
It doesn't sound like the trans, the sound comes from the rear of the car. |
| Tips on Driving a Manual Trans | Zabo | General Automotive + Other Cars Discussion | 23 | 01-14-2013 03:35 AM |
| manual trans | The BIRDman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 45 | 03-27-2009 10:42 PM |
| does the LS3 have Active Fuel Management? (Manual Trans) | ignito4909 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 31 | 02-12-2009 09:31 PM |
| Automatic faster than the manual??? | 2sharp | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 319 | 09-30-2008 09:20 AM |
| Manual Trans in The ls3 v8 ?? | Kelton00912 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 08-20-2008 07:56 PM |
