Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Line Lock
I wasn't sure where to post this question so if you need to move this Mods go ahead.
So I was watching the video of the Bada$$ 2010 Cassill Camaro 2SS RS with 1000 HP and saw that they put the line lock button on the shifter knob. Now I don't have a lot of knowledge about these so I was wondering what would happen if the button accidentally got pushed while driving the car. Would the tires lock up or is there a safety mechanism built into those things to prevent that. Just trying to enlighten myself here. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
I sure hope it has something in there that prevents it from locking when it's being driven.
NOICE!!! ™
I was thinking the same thing too
![]() Drives: Black 2SS Join Date: Oct 2009
Most people have a master arm switch mounted somewhere else.
![]() Drives: 99z28 Join Date: Oct 2009
A Line Lock is an electronic solonoid that controls a valve which is in line with the front brakes. Normally, the valve is open and allows fluid to pass through to the front brakes as usual. However, while the front brakes are applied and the solonoid is activated, the valve closes to trap the fluid in the front brakes keeping them applied until the control is released. So unless you flip the switch and hit the brakes at the same time should be good . It should be a switch not a button .
99 z28 a3 346ci .Motor by FUTRAL, Suspension by MADMAN 1.36 60ft 10.06 @ 132 175 hit old setup .
New setup 370ci with 88mm turbo in the works . 2010 inferno orange rs/ss 13.2 @ 108.4 stock http://getonitracing.net/ |
#6 |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
^^^^What he said.^^^^^
I used on both of my Mustangs when I raced all the time. They are a beautiful thing to have. |
#7 |
Drives: Anything I want Join Date: Oct 2008
#8 | |
I answered your question elsewere. Andy |
#9 | |
Thank you Viper. With your description and Andy's reply a light bulb has gone off, however dim it may be, he he he. T.
| transmission cooling line leak-from factory | SS4PK | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 21 | 12-23-2021 05:57 AM |
| 2010 Drag wheels are out!! Line lock system to follow | SJM | Wheels / Tires | 63 | 04-21-2010 01:48 AM |
| 2010 Camaro Line Lock Kit? | Windy City | Wheels and Tires Talk Sponsored by The Tire Rack | 15 | 11-09-2009 11:05 PM |
| Was I out of line? | brooks35 | General Automotive + Other Cars Discussion | 94 | 10-09-2009 08:57 PM |
| # of Cars on Line...? | carguy | 5th Gen Camaro SS LS LT General Discussions | 6 | 06-09-2009 12:32 PM |
