Old 02-11-2010, 03:39 PM   #1
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Weird Sound on my LS3..!!
Finally I have installed my ARH LT 1 7/8 no cats 3 inch connected with 2.5 inch Borla axel back BUT I have a weird sound comes only when the RPM reaches between 2500 to 3000 while the car is moving especially when I am in 3rd or 4th gear??
Does any one know or faced this issue before? Thanks
ProudLS is offline   Reply With Quote
Old 02-11-2010, 05:20 PM   #2
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
Yea, what does it sound like and where is it coming from? (engine compartment, under the car, behind the car).
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 02-11-2010, 08:02 PM   #3
Russell James
Russell James's Avatar
Make sure the heat shields underneath are not contacting anything. If the cats or anything else touches the heat shields it can make a buzz or grind type of noise. Look for the closest points of possible contacts and push the shielding farther away.
If it's not a shield contact, check for leaks. Maybe retighten the connections after a bit of driving.
Old 02-11-2010, 08:04 PM   #4
Russell James
Also, how does it sound? That's a combo I may be thinking of.
Are you using the S Borlas, the loud ones? Any drone in 6th at highway spd?
Old 02-11-2010, 08:24 PM   #5
ProudLS
ProudLS's Avatar
Drives: Camaro SS
The sound is coming from the axel back, nothing is touching I am sure, before I have my borla I used to hear it so loud but after installing it ( S type) the noise is less now but very clear at 3000 RPM after that it goes..!!
I thought maybe coz I have 3 inch pipes without cats that makes the sound?! I do not know.
Old 02-11-2010, 08:27 PM   #6
ProudLS
ProudLS's Avatar
Drives: Camaro SS
The sound is awesome I really recommend it, you wont find a better combo
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 05:15 PM
Any sound clips of 3" Magnaflow on stock LS3 caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 01-03-2010 06:22 PM
Wind Tunnel Sound Steve Dallas 5th Gen Camaro SS LS LT General Discussions 1 12-26-2009 09:51 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
