Old 02-13-2010, 12:42 PM   #1
2010Inferno
Drives: 2010 Chevy Camaro 2SS/RS IOM
2010 Camaro 2SS/RS M6 Rough idle problem
I just bought my Camaro 2 weeks ago and I have an issue with a rough idle. You can feel the car shake and watch the RPMs fluctuate as well. Dealer said it is fine and due to lean idle conditions for emissions. Just curious if others gad same problem as me.
2010Inferno is offline   Reply With Quote
Old 02-13-2010, 12:43 PM   #2
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
How many miles do you have on the car?
TommyTSquared is offline   Reply With Quote
Old 02-13-2010, 12:46 PM   #3
2010Inferno
920
Old 02-13-2010, 12:56 PM   #4
Russell James
Russell James's Avatar
Best thing to do with things that are questionable and they think it's normal, ask them to start another SS right next to yours. If they both idle the same way, normal.
It's not going to have a dead smooth idle, but shouldn't be too objectional. Just the very slightest shake from a bit of a performance oriented cam.
Old 02-13-2010, 01:11 PM   #5
Chief Bob
Chief Bob's Avatar
Drives: 2012 Camaro ZL1 SIM CTF Car M6
What he said
Remember it's a Camaro
2012 ZL1,CTF Car, SIM MN6, Polished Wheels,The Rare Flat Black Insert.
Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club"
Chief Bob is offline   Reply With Quote
Old 02-14-2010, 05:52 PM   #6
kauffjd3
kauffjd3's Avatar
Drives: 2SS/RS RJT
i can't see my rpms move but i did feel a little shake at idle. it is kind of miss leading because the car is so nice and new. almost forget what a muscle car should feel like!
2SS/RS lS3 RJT, 3in SLP Catback
kauffjd3 is offline   Reply With Quote
Old 02-14-2010, 06:22 PM   #7
sfgiantsfan9
Drives: Camaro 2SS/RS and 2001 Ford F250
I felt like my idle was really rough as well. I was expecting some shake from the cam but I thought it was a little excessive. I even started a thread about it. For the hell of it, I tried the fuse pull. Trying to get every last HP out of her and figured it couldn't hurt. Well I didn't feel any performance gains like the L99 guys do but I do feel like it smoothed out my idle. Still shakes but seems much more mellow now. Also seemed to improve the smoothness of my shifts. Could be just my head because I am getting used to the car now but it's worth a shot. Can't hurt anything to try.
sfgiantsfan9 is offline   Reply With Quote
Old 02-14-2010, 07:19 PM   #8
67MellowYellow
67MellowYellow's Avatar
Drives: 2010 SS/RS ABM M6
These LS3 and my previous LS1 engines jump around a little at idle. I would expect the L99 to do a little better with VVT and the fact that in drive, the engine is loaded a bit and typically will smooth the idle some.
67MellowYellow is offline   Reply With Quote
Old 02-14-2010, 07:50 PM   #9
mikel441
mikel441's Avatar
Drives: 2014 Sonic, 2010 Camaro SS
The LS3 shakes a bit at idle. Its due to the camshaft lobe profile(high lift/split duration). This has been discussed before many times. Do some searching and you will find more info.
mikel441 is offline   Reply With Quote
Old 02-14-2010, 08:33 PM   #10
vdevine
vdevine's Avatar
Drives: 2010 Black SS
Do the fuse pull as found on this site. They may have filled it with lower octane fuel. Worth a try anyway.
Vince
SS2 Black with CGM Stripes
3800 Born: 25 May VIN#12136
6000 Mine 26 June 2009
SLP Loudmouth II, NOWEEDS, BMR 1.4/1.0 Lowering Springs, Cold Air Inductions Intake, Tune, Eagle Eyes w HID, SLP "SS" Grille Insert, Pistol Grip Shifter, Hawk PC Pads, RGB Scanner, Tint, Headlight Armor, Clear Bra, 22's.
vdevine is offline   Reply With Quote
Old 02-14-2010, 08:36 PM   #11
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Its called having a v8.
What you feel is the lope of the cam.
SleepWarz is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 04-02-2020 05:32 PM
