Old 02-13-2010, 06:59 PM   #1
Blue Angel
Blue Angel's Avatar
Drives: 2010 LS ABM
Hitting reverse by accident?
The other day, when stopped at a light, I went for first gear and accidentally pushed past the gate and put it in reverse. Fortunately I heard the beep and slipped back into 1st before taking off.
It seems a bit too easy to get into trouble with this - at least with the V6 -M6 trans where R is to the left of 1st gear.
Has anyone else had trouble with this?
Blue Angel is offline   Reply With Quote
Old 02-13-2010, 07:52 PM   #2
Fast1
Fast1's Avatar
Drives: 2010 Summit White SS
I did when I was test driving the v6 after the v8!
Fast1 is offline   Reply With Quote
Old 02-13-2010, 08:05 PM   #3
Russell James
Russell James's Avatar
First time I drove a V-6. Somewhere is an engineer that deserves a boot in the ass for that design.
Old 02-13-2010, 08:10 PM   #4
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I did it once, but you actually have to press over with a lot of force to get it in reverse. I found I merely just go to second, all the way over to the left and down, and then go straight up.
skuttduck is offline   Reply With Quote
Old 02-13-2010, 08:23 PM   #5
CloudXTC
Drives: 1LT|RS|SIM|M6|BA Stereo
never happened to me... to get into reverse on my car takes a bit of effort and that R comes on up the display... but getting into first is no issue... just based on the difficulty ive not had the mistake...
1LT | RS | M6 | SIM | BA Stereo
1000 - [07-23-2009] Order Made at dealer
1100 - [08-04-2009] Preliminary order accepted
2000 - [08-25-2009] Accepted by GM
3000 - [09-01-2009] Accepted by production control TPW = 10-05-2009
3300 - [09-28-2009] Scheduled for production
3400 - [10-01-2009] Broadcast - Being Built
3800 - [10-13-2009] Produced - Built- VIN 2G1xxx54917
4200 - [10-19-2009] Shipped
5000 - [10-19-2009] Delivered to the dealer
6000 - [10-20-2009] Delivered to the customer
CloudXTC is offline   Reply With Quote
Old 02-13-2010, 08:52 PM   #6
Number 3
Hail to the King baby!
Number 3's Avatar
There is a beep and the DIC comes up "R" if you put it in reverse.
Old 02-14-2010, 07:43 AM   #7
GEN-IV
Right Cam
GEN-IV's Avatar
Drives: 2010 LS3 / 79 Z28
Who is the vendor for this transmission?
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 02-14-2010, 08:05 AM   #8
Number 3
Number 3's Avatar
V6 manual comes from Aisin.
V8 manual comes from Tremec.
Old 02-14-2010, 01:19 PM   #9
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
CAMARO
Old 02-14-2010, 01:40 PM   #10
Bert
synergy-green with envy
Drives: Cam....ry :-(
that happened to me when I test drove a 1LT manual . . . luckily it was at a stop light and the beep saved me . . . I guess it is an old habit from previous manuals where you make sure you're in first by pushing it all the way over to the left and it's OK if you hit it a little hard because it has nowhere else to go . . . it does take a bit of extra force, but I thought it happened a little too easily
I wonder what would happen if you did it while trying to grab first in a tight corner?
Bert is offline   Reply With Quote
Old 02-14-2010, 01:47 PM   #11
Bama_SIM_Cam
QuickSilver
Bama_SIM_Cam's Avatar
Drives: LS SIM Stick
I haven't done it (gone into reverse by accident) without knowing about it (the beep or the "R" on the dash) but I have gone into R without meaning to several times on the V6 manual. It is too easy to do so IMHO, it should have an extra collar on the shifter that you pull up or push down to get into R (I don't know the real name of this type of control).
I usually go into second then up to find first as has been previously described.
I have owned many cars with manual tranny's, they all have their own quirks. The LS is a smooth shifter, one advantage of the power the v6 has is it will pull in any gear, it is hard to be in the wrong gear, the rascal just pulls:-).
Bama_SIM_Cam ~ Oneonta, Alabama
Bama_SIM_Cam is offline   Reply With Quote
Old 02-14-2010, 02:14 PM   #12
Buckbo
Buckbo's Avatar
Drives: 2010 Camaro
Instead of looking for first at a red light, look for second (left and down) then go straight up into first. If you go too far it won't go down.
Buckbo is offline   Reply With Quote
Old 02-14-2010, 02:18 PM   #13
deibelsan
1st Camaro, Love it
Drives: 2010 2LT M6 Black/Black sunroof
I've done it a couple times but only once when I was in a "hurried" situation. Just gotta be smooth and not forceful going over to 1st and you won't get reverse. You actually have to push over pretty quickly and forcefully to get in reverse.
deibelsan is offline   Reply With Quote
Old 02-14-2010, 02:21 PM   #14
bballr4567
Drives: 2016 Camaro 1LT M6
I did it 3 times while test driving a LT M6. Way too easy to put it into reverse. It should be next to second or next to fifth.
bballr4567 is offline   Reply With Quote
Reverse Concern in 6-Speed Manual 2SS DkknightX 5th Gen Camaro SS LS LT General Discussions 31 01-08-2016 03:53 PM
SIDE MARKER, REVERSE LIGHT AND TAIL LIGHT TINT!!! BLACK10 Exterior Parts & Accessories 561 11-18-2010 11:55 AM
Can't shift into reverse!!! surferbarney Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 09-02-2009 05:09 PM
GM may seek 1-for-100 reverse stock split alienjimmy General Automotive + Other Cars Discussion 18 05-06-2009 11:41 AM
Cowl Induction hood and reverse lights on 5th gen rray200 5th Gen Camaro SS LS LT General Discussions 77 01-15-2008 12:30 PM
