Old 02-15-2010, 11:36 AM   #1
Gnarlygianni
Gnarlygianni's Avatar
Drives: Black Camaro 2SS
3000 miles time for an oil change
what oil do you guys suggest?
Gnarlygianni is offline   Reply With Quote
Old 02-15-2010, 01:20 PM   #2
kentf
Drives: 2010 camaro Black/White Stripes SS
Go with Mobil 1 full syn. That is what comes in the engine from the plant. GM must know something or they would not put it in. That is all I ever us in any of my vehicles. Really good stuff!
kentf is offline   Reply With Quote
Old 02-15-2010, 01:40 PM   #3
Eski7399
Arizona All Gens
Drives: 2SS/RS, M6, IO-Int
+1
I am considering Royal Purple though for my next change.
Eski7399 is offline   Reply With Quote
Old 02-15-2010, 02:28 PM   #4
Number 3
Hail to the King baby!
Number 3's Avatar
Change your oil when your oil life monitor suggests, not the interval your oil change shop recomends. It will save you money a lot if you use Mobil 1.
There is a lot of technology behind the OLM.
Old 02-15-2010, 02:34 PM   #5
n!ght r!der
That Guy
n!ght r!der's Avatar
Drives: really good
Mobil 1.. and if you got some extra dollars you might as well try RP
n!ght r!der is offline   Reply With Quote
Old 02-15-2010, 03:33 PM   #6
kentf
RP is an excellent choice also.
Old 02-15-2010, 03:59 PM   #7
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
You'll be happy to know I've got 5050 miles on mine and still have the original oil in it. Onstar says I will need to change my oil around 10,000 miles.
skuttduck is offline   Reply With Quote
Old 02-15-2010, 05:04 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I actualy had quite a bit of crud in my LS3 factory fill oil at that point so, yes I think you should do a change now. Mobil 1 was the right stuff and you can't go wrong with that. I am sticking with the computer intervals after that.
I also changed the fluid in my 6M. The original stuff looked totaly clean when it came out but the synchronizers REALLY like the new Mobil 1 synthetic ATF I put in there. I would advise all SS guys with manual trannys switch to that fluid. It works much better than the stock fluid. It is rather stinky though.
The rear end is next on my list but no big rush. I have some RP left over from a while ago that I might try in there. It wasn't good for my 40 year old Muncie but lets see how it works in the new Camaro differential.
Hope this helps,
-Mark.
Old 02-15-2010, 07:12 PM   #9
2SS10
2SS10's Avatar
Drives: 2010 Black 2SS LS3
How about time. I've had the Camaro for 5 months now.......only 1600 miles.
2SS10 is offline   Reply With Quote
Old 02-15-2010, 07:42 PM   #10
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Is there some reason you do not believe what's in the owners manual?
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 02-15-2010, 08:00 PM   #11
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
3000 miles is a waste of money. The shops tell you this to get you in more often so they have more chances to upsell you something. I do my own maintenance and repairs most of the time. I changed my oil at 2500 again at 5000 and will now go by the oil life monitor. I did the two early oil changes to make sure everything was fine and to get the breakin crud out. As for Royal Purple, if I remember correctly, it is not GM approved and neither is Amzoil. I think they are great oils, but I'm sticking with Mobil 1 for now.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 02-15-2010, 08:05 PM   #12
2SS10
2SS10's Avatar
I don't recall seeing a time frame. At the current rate, the oil is going to be almost a year old when the car has 3000 miles. Never had to deal with synthetic. Maybe time is not a factor.
Old 02-16-2010, 08:51 AM   #13
GRSCAMARO
RS 10 SS
GRSCAMARO's Avatar
Drives: 2010 ABM RS/2SS L99
The owner's manaul states to change the oil at least once a year.
Best 1/4 Mile Run: 11/20/2010 SGMP 13.299 @ 106 mph (2.05s 60ft)
Mods to Date:
Painted Rally Stripes by Body's by Doug
ABM Painted Splash Guards & Engine Cover
Tinted Windows by Sunbusters
CAI Kit by Cold Air Inductions (installed at C5FestI)
GRSCAMARO is offline   Reply With Quote
Old 02-16-2010, 04:13 PM   #14
bumblebeecamaroSS
bumblebeecamaroSS's Avatar
Drives: BUMBLEBEE!
i'v got aound 6k miles and still using original oil
also heard RP isnt very great to use on these
bumblebeecamaroSS is offline   Reply With Quote
2LT first oil change today--not happy mamaro Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 37 09-16-2009 03:04 PM
Help - Oil change hasn't been done yet @ 4500 miles firstmate Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 13 08-30-2009 10:42 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
