Old 02-16-2010, 11:35 PM   #1
Wvallediego
Wvallediego's Avatar
Drives: Inferno Orange 2010 RS SS
REAR END OR TRANNY LIMITIONS ON M6
DOES ANYONE HAVE ANY IDEA HOW FAR TO PUSH THE REAR END OR TRANNY M6 WITH AN LS3, SUPERCHARGE BEFORE ANYTHING SNAPS BROKEN OR APART????
Wvallediego is offline   Reply With Quote
Old 02-17-2010, 12:01 AM   #2
67MellowYellow
67MellowYellow's Avatar
Drives: 2010 SS/RS ABM M6
Push it until one breaks and then back off a click.
67MellowYellow is offline   Reply With Quote
Old 02-17-2010, 12:27 AM   #3
Wvallediego
Old 02-17-2010, 08:22 AM   #4
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
I only have about 500 miles on mine and it has been fairly cool weather so not much traction but I have hammered mine several times with 650 rwhp and over 600 ft-lbs and nothing has broken yet. I know others have broken parts.
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 02-17-2010, 11:12 PM   #5
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
you need to take the measures to minimize breakage, the tr6060 is rated at 700 hp & tq, as long as you dont have one with one of the questionable output shafts, the weak link here is the clutch, upgrade to a good quality twin disc, centerforce is my choice. next move on to the rear end, not many break except for axles, driveshafts at the pinion flange. main cause is excessive diff movement in rear subframe. install good quality diff housing and rear subframe bushings and a hotchkis chassis brace to eliminate as much movement as possible, less play = less breakage, make sure to properly torque the driveline flex discs and use loc-tite. done correctly and your good for approx 700 hp.
urr2slo is offline   Reply With Quote
Old 02-17-2010, 11:22 PM   #6
Wesman
Wesman's Avatar
Drives: Trans Am
I agree.
The majority of failures are caused by stress on components due to soft bushings, mounts, ect. These components can't take the abuse of hard launches and high horsepower, and when they flex, they throw everything else off. Amazing the damage that can be done to transmission tail housings and pinions due to excessive movement.
As you said, the TR6060 alone is rated to 700ft/lbs, and I've heard from Tremec directly that the spec is a "very conservative" number. Guys run over 700ft/lbs through Viper spec T56's, and with the upgrades to the TR6060, those kinds of numbers are nothing
Wesman is offline   Reply With Quote
Old 02-17-2010, 11:31 PM   #7
pleigh
pleigh's Avatar
Drives: 2010 CGM 1LT A6
Whoa...
1LT A6, 19" polished rims, MRT 1.0 exhaust, Boston Acoustics, C&C package, Tint
NO, the Rev limiter is not set to 118MPH... and YES, driving in this manner does affect MPG...
pleigh is offline   Reply With Quote
Old 02-18-2010, 03:55 AM   #8
Wvallediego
Originally Posted by pleigh View Post
Whoa...
Old 02-22-2010, 01:05 AM   #9
GQ4Life
Drives: 2010 Camaro SS LS3
I think its the guys putting on the big slicks at 650wHP or higher breaking axles.. pulling the 1.5 and lower 60foots..
Im curious as to what level the clutch is good for.. 600HP?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up PfadtRacing Suspension / Brakes / Chassis 9 01-28-2014 08:15 PM
Rear End Gear Question Badger V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 01-09-2010 01:11 PM
VERY LOUD POP FROM REAR END My new Camaro 5th Gen Camaro SS LS LT General Discussions 17 09-20-2009 02:23 AM
Rear end gear 3.73 - where to buy? rpepka V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 09-17-2009 06:23 PM
Rear end whine while under load shiftz33 5th Gen Camaro SS LS LT General Discussions 4 08-12-2009 05:15 PM
