Old 02-17-2010, 10:50 AM   #1
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
Engine Power Reduced Problem LS3 M6
Well, this just happened to my fiancee' to this morning. She saw the check engine light, traction control light and " engine power reduced" message on.
So she called me at worked and asked if I had done anything to her car yesterday and I was like "no". She just went back to her car and it doesn't do it now. We have no mods done to the car and it is 100% bone stock with 5800 miles. Anyone know what is going on?
fieldgoal00 is offline   Reply With Quote
Old 02-17-2010, 10:57 AM   #2
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
You have some kind of problem with your throttle or gas pedal. The system will reset itself when you turn the ignition off. It should have a trouble code stored in the pcm. Take it to the dealer and get it checked.
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 02-17-2010, 03:02 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
ask Onstar to run a diagnostic check
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 02-17-2010, 06:37 PM   #4
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
maybe she put bad gas or low octane gas in the car??
SSTony is offline   Reply With Quote
Old 02-17-2010, 06:51 PM   #5
Ghost of Vincent Price
Banned
Drives: 2010 Camaro
Thats also an over heat condition if I remember correctly.
Ghost of Vincent Price is offline   Reply With Quote
Old 02-18-2010, 04:06 AM   #6
Inferno2SSRS
Jim
Inferno2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS Orange
Send a message via AIM to Inferno2SSRS
It will happen again, bring it to the dealership immediately. I drive a lot of impalas and have had that happen a few times, usually from beating the hell out of it. Check the oil too, it may be low, but the dealership will be able to identify the problem.
Inferno2SSRS is offline   Reply With Quote
Old 02-18-2010, 09:12 AM   #7
fieldgoal00
I can assure you she hasn't beaten the hell out of it. It's got 5xxx miles on it and I've changed the oil twice already with Royal Purple. This car is babied. And as far as an overheat problem, it was in the 30's yesterday morning when it happened. She had Onstar run a diagnostic and it has to do with the throttle sensor. She dropped it off at the dealership this morning.
Old 02-18-2010, 09:13 AM   #8
fieldgoal00
93 Shell has been put in the car since the dealership filled it up
Nitrous info CamaroSpike23 Forced Induction - V8 65 03-19-2020 09:22 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 10-01-2009 01:55 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
