Old 02-17-2010, 06:58 PM   #1
sfgiantsfan9
Drives: Camaro 2SS/RS and 2001 Ford F250
1000 mile oil change questions
Just hit 1k on my as ls3 and want to change the oil in her just to get those shavings out as I've been breaking her in somewhat hard. Other than new oil filter and fresh oil is there any other fluids or anything else maintainance wise I should tak care of at 1000 miles? Thanks
sfgiantsfan9 is offline   Reply With Quote
Old 02-17-2010, 07:01 PM   #2
Russell James
Russell James's Avatar
I'd also do the rear differential. It's easy and only takes 1 qt. I used Royal Purple that includes the limited slip stuff. I was surprised how crudy the rear diff lube looked after very few miles. I think the limited slip clutches really shed a lot of material as they are breaking in.
Old 02-17-2010, 07:49 PM   #3
Class1E
Class1E's Avatar
Drives: 2010 Camaro SS
Some have also been changing transmission fluid.
Class1E is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
First Oil change concerns OBSSEST Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 43 07-24-2011 06:59 PM
500 mile oil change (metal shaving) Treadstone Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 36 11-17-2010 06:10 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
