Old 02-20-2010, 01:02 PM   #1
Dano
Dano's Avatar
Drives: 2022 Camaro 2SS 1LE M6
? for those with Magnaflow Comp Catback.
I have searched the forum and can't find any who has asked before so here goes. Exhaust is the 16482 2.5" Magnaflow Comp. Series.
Are the D/S & P/S mid pipes supposed to touch the cross member support that goes on near the end of the heatshield? I think I may have installed the muffler sub assembly upside down. The directions were not very clear.
The car has a drone while curising around 65-72 MPH, it is always there while in 6th gear between 1800-2100 RPM. This is right at the crusing speed.
So just wondering if anyone else with this set up has any drone there and if there pipes touch that cross member support.
Thanks for any help or advice you may have.
2022 Shadow Gray 2SS/1LE, M6, PDR
Dano is offline   Reply With Quote
Old 02-20-2010, 01:43 PM   #2
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I have the Magnaflow street and I know what you're talking about as far as the exhaust making contact with the crossmember. My Magnaflow street also made contact with the crossmember (caused a bad vibration noise). We had to re-adjust everything so that the exhaust wouldn't make contact anymore (1/2'' clearance).
You can also purchase a new crossmember that provides more clearance. There's a couple companies that sell them. If you can't get the exhaust away from the crossmember, that might be something to look into.
Old 02-20-2010, 02:18 PM   #3
Dano
Dano's Avatar
How do you like the Kooks? I have been looking into those also and thanks for the info.
Old 02-20-2010, 03:35 PM   #4
Hyp
I've been lost...
Hyp's Avatar
Drives: 2010 SW 2SS/RS W/IOM LSA Swap
I have the 3" system from magnaflow with kooks LT headers and cats. The drone is tolerable but its def loud. It does touch the cross member but they put a piece of rubber between it so I dont hear any clinging. I love how deep the sound is with this system!
Hyp is offline   Reply With Quote
Old 02-20-2010, 03:39 PM   #5
SGOS252382
SGOS252382's Avatar
Love the Kooks. They fit great and I went from 12.9 to 12.5 in the 1/4 mile.
Old 02-20-2010, 03:52 PM   #6
b737swaca
b737swaca's Avatar
Drives: 2010 SSRS
I have the 16580 cat back comp series. When first installed there was little clearance and it would hit the crossmember when I would hit a bump. I loosened all the clamps and rotated the pipes to give more clearance and now it is fine. Hope you can do the same.
b737swaca is offline   Reply With Quote
Old 02-21-2010, 09:25 PM   #7
Sherwood SS
Sherwood SS's Avatar
Drives: Black SS/RS
I have the 16580 too and it hit as well. you can use a couple of spacers to give it extra room to it won't hit. I had to loosen the whole system and retighten it to get it to sit right. This exhaust systems sounds awesome!
Black SS/RS - Magnaflow Comp Series, Eibach Suspension, Roto-Fab Intake
Sherwood SS is offline   Reply With Quote
Old 02-22-2010, 12:14 AM   #8
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
If you loosen the whole system, there should be enough clearance to push it up some, and then retighten.
MarylandSpeed is offline   Reply With Quote
Old 02-22-2010, 08:44 PM   #9
Dano
Dano's Avatar
Thanks for all the input everyone. I will loosen it all up and make the adjustmets. I hope it helps.
Old 02-26-2010, 03:00 PM   #10
Dano
Dano's Avatar
Well it's all fixed now. I loosened up everything and made the adjustments. It sounds great now. The drone is gone and so is the vibration it had. It sounds like it should now. Thanks for all the help everyone.
Old 02-26-2010, 04:59 PM   #11
b737swaca
b737swaca's Avatar
Drives: 2010 SSRS
My ½ price version of the Magnaflow 2.5” Comp Series exhaust caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 135 10-28-2012 12:27 PM
Kooks 1 7/8 and Magnaflow 2.5'' street catback SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 01-26-2011 11:56 AM
Magnaflow catback spinetexas V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 02-10-2010 05:02 AM
Magnaflow Comp Axle Back Before/After Magnaflow X-pipe 66DeuceLS1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 02-02-2010 12:28 AM
Magnaflow Comp axle back 5" question mikeSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 12-29-2009 08:34 AM
