Old 02-20-2010, 06:40 PM   #1
honeybucket99
Drives: 2SS/RS CGM CAMARO BEAST
trunk lid vibration
Got a serious vibration whenever I play anything with a little bass. I thought it was coming from the rear deck but isolated it to the trunk lid at the rear window...if I push on the trunk from outside all vibrations stop. Now does anyone know how to stop that damn rattle? Would dynamat or equal help? Some sort of shim? Any thoughts are appreciated.
honeybucket99 is offline   Reply With Quote
Old 02-20-2010, 06:57 PM   #2
strauchpete
Drives: 2010 Camaro 1LT
is it the trunk or spoiler?
strauchpete is offline   Reply With Quote
Old 02-20-2010, 11:46 PM   #3
coolcamaroZ28
Camaro Addict
coolcamaroZ28's Avatar
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS
I had this same problem after adding a ******** system to my 2SS. I tried dynamating the trunklid (under the carpet of course) and it helped a little, but there was still rattling from the trunk where it meets the window and applying the slightest amount of pressure in the center would stop the rattle. I installed a thin piece of self-stick weatherstripping I got at Home Depot and it worked - no more rattles!
coolcamaroZ28 is offline   Reply With Quote
Old 02-21-2010, 01:41 PM   #4
n-shane@hotmail.com
n-shane@hotmail.com's Avatar
Drives: 2010 MAROOOOOO
omg i got 2 12s and wow does that lid vibrate. haha i have all dynomat. think i may try your weather strip thing. where exactly did you put that at?
THIS CAR IS AMAZING!!!!!
n-shane@hotmail.com is offline   Reply With Quote
Old 02-21-2010, 02:31 PM   #5
honeybucket99
weather stripping as a shim sounds like the way to go. Where did you place it on the lid?
Old 02-21-2010, 02:33 PM   #6
honeybucket99
Definitely the trunk--end opposite the latch. A small amount of pressure stops it. Problem is how to apply that pressure while driving?
Old 02-21-2010, 02:54 PM   #7
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
I had the same issue...I dynamatted the trunk lid, and the whole trunk. Stopped the rattle totally.
HaZe_X is offline   Reply With Quote
Old 02-21-2010, 02:59 PM   #8
SSCamaro2010
SSCamaro2010's Avatar
Drives: 2010 Camaro 1ss/rs
pics of weather strip would be great
SSCamaro2010 is offline   Reply With Quote
Old 02-21-2010, 03:38 PM   #9
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
I'm about to put in a solobaric l7 and would like to see exactly where u are talking about!
chrisgalles is offline   Reply With Quote
Old 02-21-2010, 04:05 PM   #10
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Get some dynamat quick. There's nothing more funny than someone rolling down the street with their system banging and all you hear is their trunk going crazy. lmao.
My 1st car was a cavalier and I installed my entire system on my own when I was 17. My trunk was sounding R I D I C U L O U S. I bought a big sheet of dynamat from audio express and put in in the entire trunk my self. I removed all the cloth and padding, the spare wheel and just cleaning all the panels well with soapy water and dried it. I applied the dynamat with a roller and that was it. I only had a sony xplode amp (forgot how many watts) and 2 xplode 12s and put most anyones system to shame only because my trunk did not rattle. Makes a world of difference.
Weather strip the trunk lips too.
Also I found that the ratteling is reduced even more if I drop down 1/2 the backseat (so you can see into the trunk from inside the car) - this gives the bass/vibrations more air to flow through so it increases the number of panels that get vibrated, decreasing the magnitude of vibration. This means if your bass is limited to the trunk all the panels of your trunk will take the brunt of that bass/vibration. Open up the backseat and now the brunt of the vibration will be spread over the entire car rather than just the trunk and the rattleing will be less pronounced. Im not a sound engineer so dont quote me on this paragraph, it works but my explaination may be wrong. lol.
PS dynamat the rear license plate too!
Old 02-21-2010, 04:15 PM   #11
scythezo6
scythezo6's Avatar
Also put dynamat on the interior panel where your back speakers are bolted in. Once the trunk gets dynamatted this will vibrate and it sounds like the back window wants to pop off. Basically you chase the the rattleing around the car with dynamat until it goes away.
Old 02-21-2010, 08:12 PM   #12
coolcamaroZ28
Camaro Addict
OK, Here's some pics of the Dynamat...
And the weatherstrip along the edge of the trunk nearest the window...
Here's the weatherstrip I used...
Old 02-21-2010, 08:34 PM   #13
chrisgalles
TEXAS FIGHT!
Drives: Awesome
Thanks for the pics and the info. for the weather stripping... I'm gonna make sure my trunk is lined and everything before I get the sub/amp installed next month!
Old 02-21-2010, 08:43 PM   #14
camaroMSUfan
camaroMSUfan's Avatar
Drives: 2SS/RS Silver Ice Metallic
is this with stock speakers? and do u have any aftermarket subs or amp with it?
Mods:
Borla S-type exhaust
tinted windows
Kicker CVR 10" subwoofer
Planet Audio 400 watt amp
Custom Built Box for amp/sub
Cold Air Inductions C.A.I
camaroMSUfan is offline   Reply With Quote
how to remove the cover on the underside of the trunk lid? spectrepig Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 12-23-2009 09:26 AM
Trunk Lid Rattle Slake Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 10-18-2009 02:07 PM
trunk lid issues nards444 5th Gen Camaro SS LS LT General Discussions 7 09-11-2009 09:00 AM
Gap below trunk lid scorpio 5th Gen Camaro SS LS LT General Discussions 8 09-24-2008 09:09 AM
