Old 02-21-2010, 09:57 AM   #1
Pokergirl
Drives: 2010 SIM Camaro SS/RS M6
nitrogen in tires or not?
would someone tell me if i should put nitrogen in my tires? just a thought because its going to start getting hot here in Ca and i want consistant tires pressures....good idea or not and how much should it cost me?
Pokergirl is offline   Reply With Quote
Old 02-21-2010, 10:04 AM   #2
Garrett
G-Man
Garrett's Avatar
Drives: 2ss Aqua Blue Mettalic
If you want the most consistant tire pressure I would use Nitrogen. That is exactly why the race car teams use it.
G-Man
Garrett is offline   Reply With Quote
Old 02-21-2010, 10:08 AM   #3
Indpowr
Drives: Corvette C6
We use it in the Camaro but not the Vette. I was told that Nitro helps keep the chrome from going bad. No idea if it works...LOL
Old 02-21-2010, 10:22 AM   #4
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Do it!
Old 02-21-2010, 12:46 PM   #5
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
There's a couple of threads on this...My feeling, it's better to use it, however, think of refills or top offs...
You can spend $16 ( or such) at Costco for a first time fill, then subsequent refills are free. However, it is SUCH a hassle to do every time I need a few pounds, that I gave up...
So, if it's easy to get, then go for it! Otherwise, it's not worth it - IMO...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 02-21-2010, 01:54 PM   #6
Pokergirl
Thanks Micheal_Js, i have a Costco membership and am going to do it... Nice car by the way!
Old 02-21-2010, 02:22 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
My feeling is that IF your tires are going to last 40-50k miles (several years), it may be worth it. Since the PZero's would be lucky to last more than 12-16k miles (~1yr), what's the point.
On the Racecar note, they're speeds and traction are tire pressure dependent so that's why they use it. For a DD, you don't need to be that precise.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-21-2010, 02:22 PM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Long as your able to keep on top of it, ya know access to the gas to fill up n down as needed... its great.
tired it but got sick of havign to take time to visit the tire dealer, wait for cars to get out of the way. Some reason they won't put a hose out front
Probably 90% air in mine again by now.
And is easier, I can fill my own tires at home 24/7
If I was richer though id pay for a tank to keep around. A small suba type tank can do like 20 tires.
2ndgenz28 is offline   Reply With Quote
Old 02-21-2010, 02:24 PM   #9
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
What....Costco? Will have to check that out.
I did it, but am sorry I did. If you will keep the tires on the car always, do it.
Top offs are an issue. I am also plan on changing wheels/tires when I go to the track. Everytime I do, I will have to reset the TPMS sensors by letting the air(nitrogen) out & refilling. That means going somewhere to do it, paying someone more money, or buying a nitrogen bottle and refilling it. I have a 5gal air bottle, but don't know if I can use that.
Did not think this one all the ay through. SOP
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 02-21-2010, 03:30 PM   #10
camaro5's Avatar
Drives: X-15 Velocipede
Interesting...
It's dry, that's a great benefit. Among other things, pressure sensors hate being drenched in moisture.
Top-offs dilute it, but perhaps it's still dry enough to provide a benefit.
Costco DOES rock the nitrogen.
camaro5 is offline   Reply With Quote
Old 02-21-2010, 03:34 PM   #11
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
If the tire shop filled my winter tires with it, then I see no need for it. I lost 5 lbs of pressure when it got cold.
Most of the "air" that you breathe is nitrogen anyhow.
skuttduck is offline   Reply With Quote
Old 02-21-2010, 04:30 PM   #12
tom692010
Drives: 4 wheels
I'm not sure how you drive but after 13k miles my Pzero" have plenty of tread life left and I've only had it 8mo.
tom692010 is offline   Reply With Quote
Old 02-21-2010, 06:19 PM   #13
Mr Twisty
Mr Twisty's Avatar
I run a 78% nitrogen, 21% oxygen, 0.93% argon mix in all my tires.
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 02-21-2010, 07:15 PM   #14
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
I must agree. I have 12k on mine and they are not even close to being done. I guess, the more you play the quicker you pay.
edog is offline   Reply With Quote
Nitrogen filled tires Buby2 USA - NY / NJ / PA 33 07-13-2013 06:59 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
Nitrogen in tires 1fine79 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 53 09-29-2009 03:39 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 06:27 PM
