Old 02-21-2010, 01:24 PM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
Widest Rim/Tire for stock suspension
I am looking for what is the widest rim/tire sizes for stock suspension.
and what offset is needed for it to work.
I search I can find it. I hear people putting 305s on the rear but no one says rims offset and I havent found anything on front tires.
Thank you in advance
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 02-21-2010, 01:42 PM   #2
GQ4Life
Well wanted wider for fronts and rears..
and wanted to look at different design wheels from the stock ones.
Old 02-21-2010, 03:01 PM   #3
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
Im running 20x10's up front w/275/40/20 tires and they just clear the strut spring base.....out back i have 20x11.5 with 305/35/20's (315/35/20's work also).....think this is about the widest you will be able to go. Tires are tucked inside the wells.
FEN is offline   Reply With Quote
Old 02-21-2010, 03:15 PM   #4
Mr Twisty
Mr Twisty's Avatar
What model wheels?
What are the offsets?
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 02-21-2010, 06:03 PM   #5
FEN
FEN's Avatar
What model wheels?
I am running the polished CCW 505a's....no idea what the offsets are?? I am also lowered 1" by Eibach.
Old 02-21-2010, 09:57 PM   #6
GQ4Life
what is the offset of the rims ?
offset will make or break if a rim fits..
Old 02-22-2010, 08:20 AM   #7
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Widest wheels/tires without interference issues are 10" wide fronts and 11" wide rears. That allows a 275 wide front tire, 315 wide rear tire. If you go with a coil-over front suspension, you can run a little wider tire up front than a 275, since the shock body doesn't interfere as much as the factory strut spring perch.
As for offsets, that information isn't really shared by manufacturers or dealers until you make a purchase. Several of us bought or rented 2010 Camaros and took the measurements ourselves, and we'd prefer to not make it easy on competitors to get this information. Buy from experienced dealers and manufacturers who know what fits.
I'm an actual 2010 SS owner, not many wheel vendors can say that.
Tony
Fquick.com/NineBall
Old 02-22-2010, 12:10 PM   #8
catman
catman's Avatar
Drives: 2010 Camaro 2SS Inferno Orange Met
Any ideas on a 20 x 11 with a 5 spoke design, big lip on rear. 20 x 10 on front and that i can stay around $1750-$2000 for set? Would like a Black center with pollished lip
IOM 2SS/RS
AFE CID
Magnaflow Mufflers
GM 10" Subs
Rally Strips
Fog, Turn Signal, and Tail light Blackouts
catman is offline   Reply With Quote
Old 02-22-2010, 11:05 PM   #9
GQ4Life
i like the BBS CH-R black
seen some other rims i like too but dont know names.. still looking and saving
Old 02-23-2010, 11:25 PM   #10
catman
catman's Avatar
Yea i like the look but I want a deeper dish type wheel.
IOM 2SS/RS
AFE CID
Magnaflow Mufflers
GM 10" Subs
Rally Strips
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
BMR Launches New Product - G8 Rear Suspension Bushing Kit (BK007) BMR Suspension Suspension / Chassis / Brakes 2 01-03-2010 03:28 AM
JDP Motorsports and Spohn Performance! Dial in your suspension! JDP Motorsports Suspension / Brakes / Chassis 3 12-04-2009 05:57 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 05:36 PM
