Old 02-21-2010, 07:58 PM   #1
Russell James
Russell James's Avatar
Is the M6 shifter supposed to move around so much while driving?
Anyone notice how much the OE M6 shifter moves around while your driving?
I'll be getting a new short throw pretty soon, but it amazes me how much my stock shifter is moving all over the place while I'm driving. I'm going to jack it up and take a peak under there just to make sure everything is tight. To me it seems like the trans is just floating around. Every bump or accel/decel change my shifter wobbles around.
Does a short throw shifter reduce all that wobbling from the bumps, or is that shifter wobbling caused by the real soft trans mount? I've had a lot of M6 GM cars and this is by far the most I've seen a shifter flopping around while driving. I'm not getting how a bump in the road makes the shifter move around.
Old 02-21-2010, 08:37 PM   #2
Eski7399
Arizona All Gens
Drives: 2SS/RS, M6, IO-Int
I noticed the movement with the stock setup. Never bothered me but I noticed it.
Since installing a short throw shifter (Barton Ind.) I don't notice it anymore. I'll try to pay attn on the way to work tomorrow.
Eski7399 is offline   Reply With Quote
Old 02-22-2010, 03:07 AM   #3
baysinger
baysinger
Drives: 2010 IOM M6 SS
I have a m6 ss and mine does not move at all. If yours is moving that much I would take it in and have it looked at.
baysinger is offline   Reply With Quote
Old 02-22-2010, 04:19 PM   #4
600hp-lpe
Drives: 2010
Don't know... I never touched the stock shifter. I had the MTI shifter since day 1.
I love the way the MTI shifter operates!
600hp-lpe is offline   Reply With Quote
Old 02-22-2010, 10:43 PM   #5
Eski7399
Arizona All Gens
After driving around all day, no movement. I would take it in to the dealer just to be safe.
Old 02-22-2010, 11:50 PM   #6
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Mine never moved on its own, just sloppy shifts
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 02-23-2010, 02:45 AM   #7
DaveT
DaveT's Avatar
Drives: 2010 2SS CGM LS3
Mine moves alot.
DaveT is offline   Reply With Quote
Old 02-23-2010, 02:56 AM   #8
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
the movement will happen on any stick shift vehicle. it's normal.
UCI CamaroFan is offline   Reply With Quote
Old 02-23-2010, 07:03 AM   #9
cschmidt1956
cschmidt1956's Avatar
Drives: Too Little time to drive....
If you are coming from a front driver into this car you will notice more shifter movement due to the shifter being direct mounted to the transmission. Most FWD cars that many of us are used too have a remote shifter and much less noise and vibration issues.
cschmidt1956 is offline   Reply With Quote
Old 02-23-2010, 08:29 AM   #10
Russell James
I'm coming from a C6 Corvette, before that a C5 Z06, before that more 4th gen F-bodies than I can remember. All Tremec 6 speeds.
I've never felt a trans flop around so much as this one. I'll jack it up tonight and make sure the trans mount is actually connected.
Maybe I'm noticing it more than some because my roads here are like a bombed out moto cross track. If I put my hand on the shifter while accelerating over bumps, the shifter is flopping around. I just can't figure out how a suspension bump induces trans movement?
On smooth roads I feel just the normal torque of the engine torqueing the trans and shifter over just a hair. But when I get into a bumpy road, I'm like Ray Charles trying to grab my shifter the stupid thing is flopping around so much.
Old 02-23-2010, 01:04 PM   #11
Stingr69
'69 Owned Since '79
Stingr69's Avatar
The shifters do flop around a bit. It is part of the NVH reduction. Not a big deal here guys. Look up from under the car and you will see the flex mounts and the counterweight designed to dampen the powertrain oscillations and vibrations. This is to help make the car smoother and quieter.
-Mark.
Old 02-23-2010, 04:56 PM   #12
baysinger
baysinger
I have had my m6 ss for 6 months now and shifter barely moves at all. If yours moves that much you might want to have it checked out. Better safe than sorry.
Old 02-23-2010, 09:20 PM   #13
summitss/rsls3
summitss/rsls3's Avatar
Drives: summit white/IOM ss/rs ls3
mine does it too. i've had a 4th gen camaro, 2 different cobras, and this ss and they have all done it. Heck even my DD 97 cavalier does it and its FWD.
summitss/rsls3 is offline   Reply With Quote
Old 02-27-2010, 05:44 PM   #14
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
My stock shifter moved around a fair amount. I installed the MGW shifter today and the movement is now gone.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 09:29 AM
Driving in manual mode.... Mr CLuTcH 5th Gen Camaro SS LS LT General Discussions 41 08-01-2010 10:25 AM
ATTENTION ANY MGW SHIFTER GUYS THAT HAVE THE SHIFTER INSTALL CORRECTION>>> READ ASAP MGW V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 11-01-2009 03:15 PM
camaro update (husrt shifter, cgm) gss9909 5th Gen Camaro SS LS LT General Discussions 24 03-27-2009 06:33 PM
Thread Size on Hurst Shifter? r0cketdr Cosmetics and Lighting Modification Discussions 0 11-18-2008 01:29 PM
