![]() Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R Join Date: May 2008
Bulletin numbers for clicking noise
Does anyone have the bulletin numbers for the issues with the clicking noises in the A6? I know some said it was something with the tranny, others said it was something with the driveshaft, etc. I just need the bulletins so when I go to my dealer I can tell them what to look at rather than the old "uh, not sure what is wrong".
I also may have a bad rear main seal :-(
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
![]() IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer) 3000(accepted to production ): 4/19/093300 (scheduled for prod ): 5/11/093400 (broadcast ): 5/16/093800 (produced ): 5/22/094150 (invoiced ): 6/01/094200 (shipped ): 6/01/095000 (at dealer ): 6/12/096000 (delivery to me ): 6/12/09 |
![]() Drives: 2010 Camaro 2SS RS (Black/Black) Join Date: Jan 2010
Im having issues as well with my A6 ... I'll post up when/if I find anything out. My cars brand new ... heard a couple clunks while shifting ... that's a rarity though, happened maybe four times ... typically drives well. I had a loss of power but that's because the dealer put in regular gas, it fixed itself with 93 octane. However what always occurs is a clunking about a second to 2 seconds after everytime i stop (in the rear, occasionally, but also rarely through the shifter)
I'll keep you posted ... also, any outside information or thoughts are welcome!!!! |
#3 | |
Mine is a tapping noise, sounds like it comes from the front passenger wheel, but you can feel it in the e-brake.
#09-04-95-001A: Clicking Type Noise from Rear of Vehicle When Shifting Between Reverse and Drive or on Hard Acceleration (Add Washer to Wheel Drive Shaft) - (Feb 19, 2010)
Subject:Clicking Type Noise From Rear of Vehicle When Shifting Between Reverse and Drive or on Hard Acceleration (Add Washer to Wheel Drive Shaft) Models:2010 Chevrolet Camaro Built Prior to VIN Breakpoint A9194726 (V8 Engine) or A9194723 (V6 Engine) This bulletin is being revised to provide VIN breakpoint information. Please discard Corporate Bulletin 09-04-95-001 (Section 04 -- Driveline/Axle). <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2404116&from=sm#ss1-2404116">Condition Some customers may comment on a clicking type noise coming from the rear of the vehicle when shifting between reverse and drive or on a hard acceleration. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2404116&from=sm#ss2-2404116">Correction Add a washer between the rear wheel drive shaft and the bearing hub assembly using the procedure listed below.
#6 |
#PI0027: Rattle Noise Under Vehicle - May Be Engine RPM Related - (Feb 3, 2010)
Subject:Rattle Noise Under Vehicle - May Be Engine RPM Related Models:2010 Chevrolet Camaro SS Equipped with 6.2L V8 Engine Please Refer to GMVIS The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#ss1-2393338">Condition/Concern Some customers may comment on a rattle noise from under the vehicle. This noise is mostly reported when the vehicle is cold and may go away completely when the engine is warm. It is possible that the internal baffles may be loose in the mufflers on vehicles produced before September 15, 2009 or the resonators on vehicles built before December 1, 2009. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#ss2-2393338">Recommendations/Instructions To diagnose loose baffles in either component, use the following method.
#7 |
#8 | |
![]() Drives: 2014 2SS/RS Spring limited edition Join Date: Jul 2009
I have the same thing, usually once everything is heated up. I can feel it in the Shifter, but never thought of possible transfer through the e barake. It is definately speed related NOT rpm related, every damm time I take it into the dealer I cannot get it to do it, go figure ![]() Any advice would be great. Thanx for any help.
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor..... MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow.... |
| Harmonic noise inside at 60 - 70 mph | camdaddy | 5th Gen Camaro SS LS LT General Discussions | 30 | 06-16-2010 10:23 AM |
| Technical Service Bulletin - Engine Noise, Anyone?? | BOOTZILLA | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 27 | 05-23-2010 11:55 AM |
| Performance Numbers - Skip Shift | fireresq157 | 5th Gen Camaro SS LS LT General Discussions | 16 | 03-23-2009 01:59 PM |
| 5th gen performance numbers are in from the top | Scotsman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2008 06:38 PM |
