![]() Drives: Camaro 2LT/RS IBM Join Date: Nov 2009
Scratch Remover
I have come about a couple scratches of varying depth throughout the paint on the car, and I have no idea which product to pick up to remove them. I stopped by walmart and looked around and decided on Nu Finish Scratch Doctor to test out (luckily I can return it for full refund if I don't like it). Are there any products y'all would recommend?
I have the IBM btw so junk like this shows up really easily.
I love crepes
Maquire's Scratch X works really well.
Detailing Connoisseur
Drives: 2010 Rally Yellow 2LT RS Join Date: Nov 2009
I like the scratch X 2.0. I usually take my PC out to remove them from the clear coat though.
![]() ![]() ![]() Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
Scratch X
I used maguires scratch x also. It worked well and was easy to use. What I'm wondering is how agressive these types of products are? How much of my clear coat did I take off to get the scratch out? Does it take a while to get thru the clear coat with scratch x ? |
#6 | |
#7 |
How deep is it if you can catch it with your fingernail ? I removed a scratch just enought so you don't see it anymore, but I can still find it. I didn't want to wear out the clear coat.
#8 |
You can catch it with your fingernail
#9 |
If you can feel it with your fingernail its probably too deep to completely remove without wet sanding. Unless its all the way down to the base coat (you can usually tell if its that deep) its likley removable with wet sanding. I wouldnt recommend trying to wetsand on your new camaro. Take it to a detailer or body shop to get those removed unless your familliar with the process.
#10 |
ScratchX took it out , but I didn't want effect the sorrounding areas so I left some of it in. I can't see the base coat, but before I strated I could feel the scratch (more like a swirl) catch with my fingernail. So I was wondering how deep that might be because I don't want to wear out my clear.
#11 |
Moderator
Drives: '99 Camaro SS #1392 Join Date: Jun 2006
As other's have hinted at, you might consider visiting a reputable detailer if the "home remedies" aren't working to your satisfaction.
Most detailers will have experience with different polishes, different pads (ie; degrees of abrashion), and the equipment to remove most swirls/scratches. ![]() Based on personal experience, when detailing cars, I could remove most swirls/scratches by hand, but after investing in a random orbital buffer and different pads, etc., they don't stand a chance now. ![]() Look around and ask for experiences with different detailers in your area. ![]() Ed |
Scratch Remover???? | mike1431 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 1 | 02-17-2010 10:08 AM |
Any one try the scratch remover pen called "Fix it"? | cyberbro | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 4 | 01-03-2010 03:28 AM |
What's the best scratch remover? | xBlackout_Camaro | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 10 | 11-02-2009 06:22 PM |
Lawn mower + camaro = scratch | c0rsa180 | 5th Gen Camaro SS LS LT General Discussions | 38 | 10-05-2009 04:00 PM |
What do you use to fix scratches? | MRK III Z28 | General Automotive + Other Cars Discussion | 7 | 01-03-2009 02:12 AM |
