Drives: 2011 CG 2SS Join Date: Oct 2009
Introducing TTP Single Turbo Camaro Kits - In-House Installations
Right now our kits are only available for IN-HOUSE installations.
Our Base Kit Includes: Precision Turbo & Engine 6262SP Billet 62mm Turbocharger # 4" Intake Cover # Billet Compressor Wheel # 3 V-Band Exhaust Exit # 2.5" Discharge # T4 Flange T-304 Stainless Steel Hot Side Tubing # ALL Hot Side tubing is professionally welded with stainless rod, for no rust. # Custom Bends for Fitment 6061 Aluminum Cold Side Tubing # ALL Cold Side Tubing in 4" Diameter, professionally TIG welded. # Powdercoated to customer choice of color (Have over 50+ colors) # Billet Aluminum M.A.F. Housing professionally TIG welded. TTP 4" Core Intercooler # 1200CFM+ Air-Air Intercooler for High HP Applications # Custom Intercooler Brackets, NO need to cut anything for intercooler fitment Fuel System # 60lb Injector Set # Kenne Bell Boost-A-Pump Supporting Components # Tial V44mm S.S. Wastegate (Choice of W/G spring) # TurboSmart Race Port OR Tial Sport Blowoff Valve # 4-Ply Reinforced Silicone # V-Band Clamps for easy service # Oil Diverter Block for Turbo Feed # Aeroquip TFE Oil Pressure Feed Line # Aeroquip -8 Drain Line To Pan # 6061 Turbo Oil Feed/Drain Fittings TTP PCV System # Custom Catch Can/Breather Turbo Setup $6650 Base Kit (Includes 62mm Turbo) $400 Turbo Upgrade to 76mm First 10 kits will receive a special price of $1400 for the following: # Installation # SYnthetic Oil Change with Filter # Dexcool # Custom Dyno Tune There are numerous options to discuss with the kit, such as boost controllers, camshafts, etc. Below you will find a 2010 Camaro with our base kit, base turbo. No other mods than just our turbo kit. Bolted on 200+ rwtq/rwhp. Boost is set at 7psi, total timing 16 degree. Pump 93 octane, no meth. |
GT88H on 416ci Dyno Results. Time for the new fuel system! In progress...
![]() Drives: SS, CTS & SRT-4 Join Date: Aug 2009
That is an insanely linear powerband...
Amazing. |
Ya.. it does drop-off up top but that's the motor wanting more! I wouldn't feel comfortable above 8psi. I also tune all them into the 11.4-11.5 air/fuel at a max 16 degrees of timing. I do add a bit more timing on the bottom end to get the turbo spooled but I'll be honest it's a tire smoker!
We just threw a 76mm on a 416ci motor, which the turbo is way out of it's efficiency range but it made about 890 rwtq at 4.5K RPM.. Stupidity! |
turbo rules!
2013 Mustang GT Black M6
#6 |
More pics!
#7 |
Nice
#8 |
Uber Member
Two questions. How much (turnkey)? ...and where are you?
1000, Dealer Order (3.06.09) - Order # NHNNZH
1100, Preliminary order accepted (03.09.09) 2000, Order accepted by GM (4.30.09) 3000, Order accepted by production control (5.7.09) 3100, Order available to sequence (5.14.09) 3300, Order scheduled for production (6.16.09)-TPW 6.29.09 3400, Order broadcast (6.30.09) 3800, Order produced (7.02.09) - 2G1FT1EWXA9123955 4000, Available to ship (7.06.09) 4200, Shipped (7.06.09) - RC# GTW 310094 4800, Rail Ramp Unload (7.22.09) 5000, Delivered to the dealer (7.23.09) 6000, Delivered to the customer (7.23.09) |
#9 |
can you do this to a camaro that has headers already?
How much HP will the camaro 75 mm turbo upgrade put out? if the base does 600 then you got to be looking around 700 ron the 76mm right? What are you doing about fuel over 600 hp?
#10 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
On that 76mm 416 cu .in set up was that with this same plumbing, and was it a stock block? thanks
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
#11 |
![]() Drives: Blown 02 SOM SS (630 hp old ride) Join Date: Feb 2010
Any option of going with a electronic boost controller?
How about going with twin in tank pumps or externeal Aeromotive instead of the BAP? |
#12 |
We are in NJ..
5 Cardinal Drive Little Falls, NJ 07424 However, we do run transports from coast to coast for pickup & delivery. We have a lot of clients that send their vehicles off to us here, fly-in and take a nice (fast) ride back home All transportation is handled by enclosed trailer, we have a 24' single and a 36' double stacker available for tow services. Locally, we use J&M Towing for quick transports to and from.We are taking a run down to Road Atlanta March 12-13th & then VIR for the 15-16th. Currently I am running one empty on the way back (Which can change very quickly), so anyone looking for pickup services can let me know we can fit within these dates. --------------------------- We have run the BAP's successfully to 650rwhp.. Past that I'd be a little weary of it. We do not currently offer a twin in-tank pump option. If you've spoke with me before, you will know I am not a fan of dual+ pumps. I prefer running one pump, main reason is if that pump fails it shuts the car off. If you lose 1 of 2 pumps, and aren't looking at a wideband or f/p gauge you have a severe risk of damaging the motor. That being said, we are currently working on an Aeromotive A1000 fuel pump setup in our shop Camaro. We are trying to make a "semi" bolt-in fuel system for the Camaro without drilling into the vehicle, the room for aftermarket fuel systems with stock tank is not the best on these cars but it is doable! --------------------------- Yes can be done to a car that currently has headers, but we'll be removing them to give back to you! The kit includes every exhaust component you need, so you can hold onto the headers or put them up for sale. We cannot use them in the current kit. --------------------------- Sure we can definitely see 700 from the 76mm... Unfortunately I don't know how long you'll see these numbers Yes we have numerous LS3's into this range, but from our own R&D here we are not the biggest fans of the LS3 pistons in particular. With heavy supporting safety mods and a good fuel system I can see it lasting for a bit, but I won't put a guarantee on it. However, throw in some forged pistons + rods and no problem to handle 800+ on a daily range. --------------------------- BknBlk: Yes same plumbing. We made all of our crossover tubing in 2.5", coupled with 3" for the exhaust discharge + intake charge (Steps to 4" after intercooler all the way to t/b). We also run the wastegate open unless customer preference is recirc'd. The reason we do this is to open up the usable exhaust, effectively making our exhaust system "larger" not running it recirc'd. Plus we have a few other specialities in the kit for anti-lag. We see full spool at the low 3k RPM mark with the 76mm I am very pleased with that. Our base kit is a bit more expensive than others, but our kit already comes with all the goodies. I can start putting in some generic turbos (We all know PTE is the best race turbo company out there), ebay blowoff/wg, no powdercoat, etc. to really price this kit down. I can buy two off the shelf B/G-M/P turbos for what one PTE billet costs. The problem is that you will be using the parts to their max potential, I am a big fan of using a much better part at part of its full potential than running "balls to the wall." ------------------------ Pricing: $6650 Base Kit (Includes 62mm Turbo) $400 Turbo Upgrade to 76mm $1400 installation, includes synthetic oil change, dexcool flush + refill, all labor + complete dyno tuning (Includes complimentary baseline pass before turbo install). So we are looking at $8050 + upgrades... Yes electronic boost controller is an option, we have a Greddy Profec B in the shop car, but we have used so numerous controllers. I prefer to stay with the Greddy P-B, Innovate MSBC (Discontinued), HKS EVC EZ controllers, but we can go into specifics + mounting locations on a per client basis. --------------------- |
#13 |
We're going to throw another bone at you guys looking for the turbo installations. We will be including a complimentary Autometer boost/vac gauge, mounting pod & full installation with any turbo install until the end of March!
#14 |
Can you wire a fuel pressure safety switch in line so if one pump fails, you'll get a warning?
I see your logic, it's all good. Can't remember where I saw it , but I saw a sumped tank with the A1000 and regulator mounted on the backside of the tank with an fittings coming out. Looked sweet. You can put rubber mounts on the a1000 to help quiet that sucker down. That'll support 1000 hp easy. I'm a fan of having a rock steady fuel pressure. I hate rising rate regulators and all that jazz. I had a BAP on my car and when I would whack it the pressure would drop momentarily then build. That makes it more difficult to tune. I had a Aeromotive regulator, 60 lb injectors, lines, bla bla bla. You should get a vid of the car with a 76 mm on the street to show potential customers how much fun a turbo car is! Can the stock clutch hold 600-650 rwhp? |
| TTP Single Turbo 62mm/76mm/88mm Kits - Preview... | Sales @ ECS | USA - NY / NJ / PA | 7 | 02-05-2016 08:37 AM |
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 07:10 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 11:06 AM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 08:33 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 08:05 PM |
