Old 02-26-2010, 10:15 AM   #1
alphaghost
Drives: 1995 honda accord
could zr1 s/c be used on camaro ss
just wondering if you could use the blower on zr1 being that the ls9 is a s/c ls3 or is there more to it
alphaghost is offline   Reply With Quote
Old 02-26-2010, 10:28 AM   #2
The_Blur
Moderator
The_Blur's Avatar
This is an unlikely possibility. The gap between the rumored 550-hp LSA and the LS3/L99 is already substantial. Throwing a nearly 640-hp LS9 in the mix leaves too much room between Camaro trims.
warn 145:159 ban
Old 02-26-2010, 10:36 AM   #3
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
The OP is asking if "Technically" is possible to use the LS9 blower on LS3 engine, so he could possibly buy the blower from GM than Magnason? I think that's what he was asking.
People like LPE or ADM Performance or Hennessey might be able to answer that question, since they have worked on LS9 engines.
Z_Rocks is offline   Reply With Quote
Old 02-26-2010, 10:39 AM   #4
alphaghost
but I mean mechanically is it possible? not in a business sense, could you use the 4 chamber s/c from zr1 and bolt it on a ls3 if you own a ss already
Old 02-26-2010, 10:40 AM   #5
alphaghost
thank u z_rocks that is exactly what i was asking
Old 02-26-2010, 10:44 AM   #6
Ghost of Vincent Price
Banned
Drives: 2010 Camaro
I dont see why you couldnt. Its the same motor essentially. But I would bet it costs more and is less effective than an aftermarket blower.
Ghost of Vincent Price is offline   Reply With Quote
Old 02-26-2010, 11:15 AM   #7
Z_Rocks
Z_Rocks's Avatar
I *think* I've read somewhere (a long time ago) that the head is different than stock LS3 head which means it would not work with LS3 head.
@OP: You're better off to buy a S/C that is designed to fit exactly the heads on LS3 (like TVS2300, Edelbrok e_Force, KB, Whipple) than trying to retrofit the LS9 S/C.
Old 02-26-2010, 11:20 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The heads are a little different, but it's my understanding the ports and locations, are pretty much the same. LS9/LSA heads are cast using a different method have swirl vanes cast in the valve bowl area to my recollection. Physically, I believe the 2300 should swap on, but I think there are probably more efficient ways to get there (i.e. aftermarket top-mounts), just like the OP said.
'20 ZL1 Black "Fury"
Old 02-26-2010, 11:22 AM   #9
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
I'm sure you could but it would cost nearly 6k for just the major components. You would still need fuel rails, injectors, throttle body, coolant system, belt system, custom tune, etc etc etc.....
So unless a ZR1 owner is literally giving you his after upgrading, it would still be cheaper to buy aftermarket.
Robert91RS is offline   Reply With Quote
Old 02-26-2010, 11:27 AM   #10
Banned
Drives: 2010 Camaro
Im pretty sure the heads are the same, just different valves and sizes. Same ports though. The ls7 heads are different.
Old 02-26-2010, 11:43 AM   #11
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
The heads are a different casting with more meat in a few critical places and swirl port intake runners. But the ports should all still line up.
Old 02-26-2010, 12:18 PM   #12
alphaghost
thnx for the info
Old 02-26-2010, 03:18 PM   #13
600hp-lpe
Drives: 2010
Would be a LOT of money spent if it didn't fit correctly...
600hp-lpe is offline   Reply With Quote
Old 02-26-2010, 03:31 PM   #14
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Would be alot of money spent if it did fit....
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 09:16 AM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
