Old 02-28-2010, 06:30 PM   #1
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
went to the track for the first time in the camaro
my first pass in the camaro while leaving on the built in launch control:
R/T ... .642
60' ... 2.147
330 ... 5.854
1/8 ... 8.807
MPH ... 84.29
1000 ... 11.334
1/4 ... 13.443
MPH ... 106.64
Done at Atlanta Dragstrip in Commerce.... track around 800 ft above sea level and done on street tires. I guess its not bad.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 02-28-2010, 09:30 PM   #2
My2SS/RS
My2SS/RS's Avatar
Drives: 2010 2SS/RS M6
Nice first run! I tried out LC for the first time at the track today as well. Best 60' with it on was 2.155 and without was 2.132. It was packed today so I only got 4 runs in. Did you let off Clutch fast or ease off slow? Tires spin or engine bog? I'm still new as this was only my second time racing at the track. Best run was with LC on, 13.022 @113.52 - 68F almost in the 12 sec stock club.
Also, are you trapping in 3rd or shifting into 4th? Sorry for all questions. Still learning
My2SS/RS is offline   Reply With Quote
Old 02-28-2010, 09:31 PM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Great job to both of you. Very nice!!!
Old 02-28-2010, 10:44 PM   #4
blake2010ss
I slip the clutch some. I'm finishing in 4th....shifting around the 1000ft. I'm expecting better e/t and MPH when I make it to a lower elevation track like silver dollar or Carolina.
1093/1066
Old 03-03-2010, 12:08 AM   #5
My2SS/RS
My2SS/RS's Avatar
I'm goin to try and shift into fourth next time I go because I'm hitting rev limiter at the finish (right at or right before - too close to tell). I'd say u should try holding 3rd a couple times and see how it works for u. The track I was at is I thnk maybe 68 feet above sea level. 13.4 at 800ft is fast. I also found I was a tad slower shifting at around 6300 vs around 6000 1st to 2nd and 2nd to 3rd. But I only tried the higher rpm shifting 1 time so could have been user error or getting out of engine powerband too much. Hoping to try again in a couple weeks.
Old 03-09-2010, 08:49 PM   #6
GRSCAMARO
RS 10 SS
GRSCAMARO's Avatar
Drives: 2010 ABM RS/2SS L99
I have never raced a car. I am signed up to hit the track at C5fest so I am reading threads trying to learn.
Silly question: Are you running all out ie petal on the floor after each shift? I have the L99 so I guess there will be a difference in how to run...
Best 1/4 Mile Run: 11/20/2010 SGMP 13.299 @ 106 mph (2.05s 60ft)
Mods to Date:
Painted Rally Stripes by Body's by Doug
ABM Painted Splash Guards & Engine Cover
Tinted Windows by Sunbusters
CAI Kit by Cold Air Inductions (installed at C5FestI)
GRSCAMARO is offline   Reply With Quote
Old 03-09-2010, 09:00 PM   #7
nhra stocker
nhra stocker's Avatar
Drives: 69,10 camaro 71 chevelle
With an automatic tranny never let off the gas. Pull around the water box , back your cars tires to where its damp , do a small burnout to clean the tires off. Pull up to the black boxes on the side of the track to pre-stage (first yellow bulb) then creep into the next bulb (stage bulb) have the car in drive and on the last yellow bulb on the tree FLOOR IT! Then let off after you see the last orange box at the end of the track.
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122
1969 Camaro (427 ZL-1 clone) M-22 being built
1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud
nhra stocker is offline   Reply With Quote
Old 03-09-2010, 09:45 PM   #8
ron10
Drives: 2010 2SS IOM L99
i think i have read where most of the guys say they get better times with the L99 in sports mode.
Old 03-21-2010, 10:54 PM   #9
My2SS/RS
My2SS/RS's Avatar
Not a silly question. I have a manual tranny and have lifted off the gas while shifting each time. As stated above, for the auto all u really do is stage up, preload for a sec before u let off brake and stay in it till the end. From what I hear u also should have it in sport mode and let car shift itself.
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
