Old 03-01-2010, 03:49 PM   #1
Eddie_B
Eddie_B's Avatar
Drives: 2SS Red Jewel w Tint Coat
Send a message via Yahoo to Eddie_B
Weird noise on V8 2ss Camaro
when i start my 2ss, after a while i hear a weird noise (metal sounding) noise coming from around the exaust area... also you could hear it sometimes when im in a complete stop and begin to go on 1st.. does anyone know what might be that noise?
Eddie_B is offline   Reply With Quote
Old 03-01-2010, 04:00 PM   #2
TIE FIGHTR
Cousin of Foo
TIE FIGHTR's Avatar
Drives: 2010 2LT RS BLACK/BEIGE
Can you be more specific?
Is it a rattling sound?
'I wish I was the full moon shining off a Camaro's hood' ~ Pearl Jam Wishlist
TIE FIGHTR is offline   Reply With Quote
Old 03-01-2010, 04:05 PM   #3
Eddie_B
Eddie_B's Avatar
i really cant say its a rattling sound, i really cant explain it.. its just some weird sound,
Old 03-01-2010, 05:42 PM   #4
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
Do you still have factory exhaust ? Or have you changed it ?
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 03-01-2010, 05:43 PM   #5
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
Sound like a tapping coming from the trunk?
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 03-01-2010, 05:49 PM   #6
jose1003
jose1003's Avatar
Drives: 2010 Camaro 2SS Cyber Gray
is it a pinging noise
jose1003 is offline   Reply With Quote
Old 03-02-2010, 07:17 PM   #7
Eddie_B
Eddie_B's Avatar
yea i stil have the same exhaust from the factory, well in a way its a ratling noise
Old 03-02-2010, 07:18 PM   #8
Eddie_B
Eddie_B's Avatar
it makes that noise when i put it to 1st and go, not all the time though
Old 03-02-2010, 07:22 PM   #9
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Are you running 87 octane? if you are that could be the noise.
ULTRAZLS1 is offline   Reply With Quote
Old 05-22-2011, 03:37 PM   #10
srsmithee
srsmithee's Avatar
Drives: 2010 Camaro 2SS/RS
I think I have the same noise you describe. It is a buzzing noise coming from the rear of the car. Sounds like a heat shield loose but it only happens when the engine is at 1100-1300 RPM and under load. In 6th gear it happens from 60mph to 63mph but it happens in any gear. Anyone else have this issue?
srsmithee is offline   Reply With Quote
Old 05-22-2011, 04:15 PM   #11
deltalion
Drives: 2010 chevy camaro 2ss
Cool
Yes, I have that issue. I took it to the dealer and they are replacing the entire exaust system, apparently the innards of the muffler came apart and were rattling around in the pipe. Take it to a chevy dealer and have it looked at.
deltalion is offline   Reply With Quote
Old 05-22-2011, 04:16 PM   #12
bthomp01
bthomp01's Avatar
Drives: 2010 2SS/RS IBM M6
Sounds to me like it could be two different things:
1) If you have the GFX kit it could be your tail pipe making contact with the chrome in the rear diffuser... I had that happened and it sounded horrendous and only happened at low RPM's
2) I've heard stories of a nut from the spoiler vibrating loose and getting stuck inside the trunk. That should be pretty easy to diagnose, just open the trunk and shake it a bit to see if that's what it is.
2010 IBM 2SS/RS - T BRUTAL
Matte Black Bumblebee Stripes - Unpainted Heritage Grille - Blacked Out Bowties - Stainless Works S-Tube Catback - CAI, Inc. Cold Air Intake
Whiteline Rear Cradle, Rear Differential, Front Radius Rod Bushings - BC Racing BR Coilovers - Installed by Whiteside Customs
bthomp01 is offline   Reply With Quote
