Old 03-01-2010, 04:16 PM   #1
MCSDS
Drives: 2010 Chevrolet Camaro V6 RS Package
Is this normal...?
I was wondering if this is normal... In the order of pictures attached below.
1. What is that square silver thing on the strut tower? It's sticked to it and don't see any function of it...
2, 3, 4. Can anybody tell me which part that is and if that is rust? Is it normal?
5, 6. What is the yellow marking? Is it from the factory?
7, 8. Surprised by this... Cable tie and a black tape wrap? Those black tapes are not even sticking on properly... Same for you guys?
Please help me out!
MCSDS is offline   Reply With Quote
Old 03-01-2010, 04:17 PM   #2
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
pictures?
AdnanHfuda is offline   Reply With Quote
Old 03-01-2010, 04:44 PM   #3
reddevilseye
reddevilseye's Avatar
Drives: rs/ss
is this v6 or v8??
reddevilseye is offline   Reply With Quote
Old 03-01-2010, 04:45 PM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Well, i can tell you the rusty thing is your stock manifolds... cast iron with surface rust... normal
scrming is offline   Reply With Quote
Old 03-01-2010, 05:12 PM   #5
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
Scrming how you like your JBAs? Any noticeable performance increase or you waiting for the track?
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 03-01-2010, 05:19 PM   #6
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
1. What is that square silver thing on the strut tower? It's sticked to it and don't see any function of it... It simply covers an opening in the bodywork. It is either an inspection hole or an access hole for assembly quality inspection
2, 3, 4. Can anybody tell me which part that is and if that is rust? Is it normal? most likely your exhaust manifold and normal as stated
5, 6. What is the yellow marking? Is it from the factory? Yup, from the factory. Used to indicate that the part has been torqued/checked for proper installation
tie wraps are common. the part that is wrapped and kinda hangin there is odd
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-01-2010, 05:23 PM   #7
scrming
scrming's Avatar
Waiting for the track... but probably have other mods on before that... lol
The change in sound however was simply incredible! Especially at idle sitting at a stop light! LOL!
Of course there is the appearance aspect... compare the OP picture of the heat shield on the manifolds with:
Old 03-01-2010, 06:20 PM   #8
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
^^are you getting a CEL from the jba shorties? I can't remember
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 03-01-2010, 06:34 PM   #9
scrming
scrming's Avatar
sort of.... I occasionally get a code but it never turns on the CEL... i typically just clear the code....
Old 03-01-2010, 07:59 PM   #10
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
Nothing abnormal. The little aluminum and mastic patch on the strut tower just seals the area to keep water out. Everything else looks good.
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 03-01-2010, 10:20 PM   #11
MCSDS
Thanks a lot!
Is this noise normal? For LS3 M6 owners only. CamaroSS_LS3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 57 06-19-2012 02:39 PM
a few camaro issues- normal? or problems? Arachnyd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 05-20-2010 11:13 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Vinyl Stripes Bubbling ... Is this considered normal? JoeySS/RS 5th Gen Camaro SS LS LT General Discussions 5 07-24-2009 12:14 AM
Vinyl Stripes Bubbling ... Is this considered normal? JoeySS/RS 5th Gen Camaro SS LS LT General Discussions 2 07-23-2009 09:58 PM
