Old 03-02-2010, 12:58 AM   #1
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Do i need to add friction modifier?
Hey guys,
Just have a quick question that i need answered by tomorrow, cause going to change out the fluid. I just bought the Amsoil diff fluid (75w90) and was wondering if i still have to add the friction modifier? It doesn't say on the bottle. Its not a big deal to buy some from chevy, so i was just wondering.
Also, if i did put the 2.6oz of friction modifier with the amsoil, will it hurt anything?
gotpball44 is offline   Reply With Quote
Old 03-02-2010, 10:29 AM   #2
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
If I remember correctly in reading you dont need to add the FM to amsoil or RP.
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-02-2010, 03:35 PM   #3
gotpball44
gotpball44's Avatar
OK cool, anyone else know?
Old 03-02-2010, 03:42 PM   #4
Moriartii
Moriartii's Avatar
After doing further research for my own fluid change, I can tell you without a doubt if you are using RP, Amsoil, or Redline you do NOT need the modifier.
Cheers
K
Old 03-02-2010, 04:26 PM   #5
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Taken from the Amsoil website: And as all Camaros have a LSD.....
AMSOIL SEVERE GEAR® (75W-90) provides superior performance and replaces competitors’ 75W-90 and 80W-90 gear oils. It delivers the best fuel efficiency and cold temperature performance of the SEVERE GEAR oils.
AMSOIL SEVERE GEAR® is compatible with conventional and synthetic gear oils. Mixing AMSOIL gear oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives, other than those specified by AMSOIL, are not recommended for use with AMSOIL gear oils.
AMSOIL SEVERE GEAR® is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
So I guess it doesn't need it unless you get chatter, on the flip side --- it doesn't appear to have a warning not to......Another thread here added the modifier.
Im changing mine with Amsoil and will add the modifier
markmass is offline   Reply With Quote
Old 03-03-2010, 12:18 AM   #6
gotpball44
gotpball44's Avatar
Hey guys,
Thanks for the responses. I just bought the Friction modifier anyways. Just going to put 2 oz of the stuff. Called amsoil and they said if i put the FM in with their fluid that it wont hurt anything.
Petition to Add Green to the Colors List. stovt001 Cosmetics and Lighting Modification Discussions 43 03-21-2010 02:52 PM
4 aux gauges add on for cars w/o them?? mtm864 5th Gen Camaro SS LS LT General Discussions 11 11-22-2009 01:03 PM
Can i add HID's to the LS FutureCamaroOwner Cosmetics and Lighting Modification Discussions 3 11-08-2009 01:41 AM
ADD Pictures to post champagne Site Related Announcements / Suggestions / Feedback / Questions 7 10-25-2008 11:23 AM
