Old 03-03-2010, 10:15 PM   #1
ambjocky
June 6, 2009
ambjocky's Avatar
Drives: 2010 Camaro
TSB Thread
Can one of he admins make a sticky for an updated list of TSB's. Seems to be one of the hot topics people are constantly looking for, but is hard to locate a list in one place.
Just a thought.
2SS-RS SIM Black Interior
RotoFab CAI
MBRP 3" Cat Back
Vector Tune
ambjocky is offline   Reply With Quote
Old 03-05-2010, 02:51 PM   #2
purplhaizcraz3
Drives: 2010 2LT CHEVY CAMARO BABY!!!!
Just a thought.
+1. I think this is a great idea. People might not know somethings wrong with their car, then they can see a list of all TSBs and see if they might've missed something.
purplhaizcraz3 is offline   Reply With Quote
Old 03-19-2010, 09:31 PM   #3
asmith10
Drives: Camaro 2LT/RS IBM
I concur we need an up to date TSB list
asmith10 is offline   Reply With Quote
Old 03-20-2010, 04:10 AM   #4
hamad_311
Drives: 2010 Victory Red Camaro 2SS/RS
gr8 idea, if anyone is new here or has just got a problem, he should drop by and look
hamad_311 is offline   Reply With Quote
Old 03-23-2010, 08:53 PM   #5
asmith10
Or at least is there a website that lists all the current TSBs?
Old 04-21-2010, 06:20 PM   #6
Patfan1987
CGM is the Best! Thx GM
Patfan1987's Avatar
Drives: 2010 2LT RS Camaro, Auto + Sunroof
+1 would be very helpfull
Proud Owner of a CGM 2 LT/RS Auto Transmission w/Sunroof and Spare Tire
Patfan1987 is offline   Reply With Quote
Old 04-21-2010, 06:37 PM   #7
BalogUK
THE architect.
Drives: 2SS/RS M6
Originally Posted by ffrcobra_65 View Post
I found this here a a couple of months ago. I hope some of you will find it useful in identifying your Camaro issue. At the very least, you have the TSB # when you visit your dealer as often times, the dealer will not have a clue.
#09-08-44-015A: Radio Display Screen Scratches and Scuffs (Polish Display Screen) - (Aug 18, 2009)
#05-06-01-034G: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Aug 12, 2009)
#09-06-03-004A: Intermittent Illumination of MIL, Service Lamps, Service Messages or DTC Set by Various Control Modules-Diagnosing and Repairing Fretting Corrosion (Disconnect Affected Connector and Apply Dielectric - (Aug 10, 2009)
#09-01-38-003A: Moisture from Center HVAC Vent When A/C is On, Front and Back Floor Carpet Wet (Realign A/C Drain Tube) - (Aug 5, 2009)
#07-08-46-002D: Audio Whine Noise from Radio Speakers When using OnStar (Install Noise Suppression Filter) - (Jul 29, 2009)
#09-08-42-005: Driver/Passenger Door Accent Lighting-Light Bar (Pipe) Inoperative or Loses Intensity (Check Light Bar (Pipe) Attachments, If Necessary) - (Jul 7, 2009)
#09-01-37-001: Gurgle Type Noise Coming from Instrument Panel (IP)/Heater Core Area (Perform Repair as Outlined) - (Jun 24, 2009)
#09-08-64-026: Front Side Door Window Squeaking Noise, Reversal During Express Up (Align/Replace Weatherstrip) - (Jun 22, 2009)
#05-08-51-008C: Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) - (Jun 22, 2009)
#03-08-44-005I: Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) - (Jun 18, 2009)
#09-08-49-011: Instrument Panel Cluster (IPC) Needle(s) Stick Intermittently (Replace Instrument Panel Cluster) - (Jun 15, 2009)
#99-01-39-004C: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating) - (Jun 12, 2009)
#09-07-29-002: Squeak Noise from Manual Transmission Shifter (Remove Material from Silver Cover) - (Jun 12, 2009)
#09-08-50-009A: Scraping/Moaning/Creaking Noise from Front Seats (Apply Lubricant) - (Jun 4, 2009)
#09-08-110-012: Windshield Side Garnish Molding Itching Noise (Install Adhesive Flocking Material to Mounting Tab) - (May 26, 2009)
#05-03-10-003D: Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) - (May 11, 2009)
#09-08-110-010: Rattle Noise in Rear Window Panel Trim (Install Adhesive-Backed Shim Stock) - (May 6, 2009)
#09-08-49-007: Instrument Panel Cluster Trim Plate Squeak and Rattle Noise (Install Anti-Squeak Fil Tape and Adhesive-Backed Flocking Material) - (May 4, 2009)
#09-08-48-003: Creaking/Itching Noise from Lower Windshield Area/Upper Instrument Panel Area (Add Foam Tape to Air Inlet Panel, Re-fit Windshield) - (Apr 9, 2009)
#09-08-48-002A: Marks/Stains on Windshield When Wet (Clean Windshield) - (Mar 19, 2009)
#09-08-64-006: Driver and/or Passenger Door Hinge Creak (Apply Lubricant to Check Links) - (Mar 13, 2009)
#09207A: Service Update for Service and Customer vehicles – HVAC Reprogram, Engine Harness Position Inspection, Rear Spoiler Fasteners – (Sept 23, 2009)
#09-08-51-005: Rear Bumper Fascia Contacting Body, Peeling Paint (revise fasteners, Refinish fascia - (Nov 6, 2009)
here y'all go- I pulled this from the "heater core" thread...not sure of the original source, but this is certainly a start.
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 04-22-2010, 07:25 PM   #8
Smokiee
Smokiee's Avatar
Drives: VR 2SS
Great Info!!
THANKS!
Smokiee is offline   Reply With Quote
Old 04-26-2010, 11:45 AM   #9
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
thanks for the info, anyone have the clutch pressure plate TSB as well as the front speakers on high bass aplications. Which is sad because my car i set with the bass on 4 and it sounds terrible
CAMARO
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 02:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 08:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 11:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 02:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 07:47 PM
