Old 03-05-2010, 05:35 PM   #1
rharp
rharp's Avatar
Drives: 2010 SVT Raptor/ 70 Chevelle SS 396
Do your own oil change !
So I went to the dealership where I bought my Camaro to get the oil changed.
When I got home I figured maybe I better check to see if the level is correct.
Guess what 2 quarts low I call the dealership to complain they say we put 6 quarts in, just what it calls for in your book this is an LS3 not a 6 cylinder. My question I guess would be did this engine get hurt by driving it home? Only went about 5 miles. Someone from the dealership is coming by with 2 more quarts to put in it but has some damage already been done? From now on I will do it myself so I know it gets done right. No more being lazy for me.
rharp is offline   Reply With Quote
Old 03-05-2010, 05:41 PM   #2
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
damn that sucks. Im afraid that theyre going to put 10w40 in mine one day.
Just a quick q, if you do your own oil changes, does this void your warranty? I was going to do so but heard this. And was told you can take it some place else but you need to have the documents to support that you are indeed getting the oil change
CAMARO
Old 03-05-2010, 05:46 PM   #3
americo
americo's Avatar
Drives: IOM 2SS RS
I have bought many new vehicles and have always done my own oil changes and have never had a problem with warranty, even with extended warranty.
americo is offline   Reply With Quote
Old 03-05-2010, 05:47 PM   #4
rharp
rharp's Avatar
I don't think it voids your warranty, you could,nt do a worse job on it than they do.
Old 03-05-2010, 06:05 PM   #5
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Do it yourself and keep a log in your owners manual along with receipts.
Old 03-05-2010, 06:05 PM   #6
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
Doesn't sound like your oil light came on. What was your oil pressure at?... as long as all this was OK on the ride home (and you weren't racing home); you should be OK.
Kenji is offline   Reply With Quote
Old 03-05-2010, 06:09 PM   #7
Jarhead
Semper Fi Camaro
Jarhead's Avatar
Drives: 2010 1SS/RS Aqua Blue LS3 Gauge PKG
This is the best practice. You can prove it if needed. Any court will support you should it ever need to go that far.
Jarhead is offline   Reply With Quote
Old 03-05-2010, 06:19 PM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Though id support my local GM dealer I would not get simple stuff done there as they hire allot of folks that are still in or right out of tech/high school.
And they get delegated those simple task like oil changes, but for some its not so simple. Mostly as the tops in the class move on to better pastures.
Cause we all know if who ever did it, put in the right amount of oil, you would not be low.
As if you siphoned 2 quarts out to get one over on them...
They had to of made the mistake and should find out why and own up to it.
Making excesses is not a good sign of a pro shop.
Id make a stink higher up above the dealer to GM corp, to make sure its looked into before they start replacing engines.
2ndgenz28 is offline   Reply With Quote
Old 03-05-2010, 06:20 PM   #9
GRSCAMARO
RS 10 SS
GRSCAMARO's Avatar
Drives: 2010 ABM RS/2SS L99
I have an Excel spreadsheet I use to keep track of maintenance. I do not know how to post it here so PM me and I will send it to your email address.
Best 1/4 Mile Run: 11/20/2010 SGMP 13.299 @ 106 mph (2.05s 60ft)
Mods to Date:
Painted Rally Stripes by Body's by Doug
ABM Painted Splash Guards & Engine Cover
Tinted Windows by Sunbusters
CAI Kit by Cold Air Inductions (installed at C5FestI)
GRSCAMARO is offline   Reply With Quote
Old 03-05-2010, 06:25 PM   #10
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
I keep records of gas use and mileage.
Pay at pump with Paypal debit[2% cash back], get a receipt, write mileage and needle position down.
Ill draw out 1/2...l.....3/4, like today I was a bit below half way between 1/2 n 3/4....
Old 03-05-2010, 06:39 PM   #11
rharp
rharp's Avatar
Thats right my oil light did'nt come on, never even thought to look down at the gage for oil pressure. They just left my house after puttin 2 more quarts in, the guy said the oil light did'nt come on because the sensor is very low in the oil pan, so the oil level has to be real low in order to trip it, HOW LOW IS REAL LOW Any way the tech wrote on the back of his card that my next oil change is free. I dont think so !!!!!!!!!
Old 03-05-2010, 06:40 PM   #12
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
http://ThirdGenChat.org/MAINTENANCERECORDS.xls
2013 5th Gen Firebird on order.
86 Pontiac Firebird [a work in progress]
[68 Firebird hoodscoops, custom notchback[1-3 built]rear mounted tach, inverted wing]
http://www.thirdgen.org/techboard/v6...-all-over.html
"In certain extreme situations, the law is inadequate.
In order to shame its inadequacy, it is necessary to act outside the law.
To pursue... natural justice.
This is not vengeance.
Revenge is not a valid motive, it's an emotional response.
No, not vengeance.
Punishment."
Old 03-05-2010, 06:42 PM   #13
Kenji
Kenji's Avatar
+1... but I always completely fill it. That way I know how much gas was used by mpg = miles driven from last fill-up / gallons filled. I also log date, where I bought the gas, price, special conditions, etc on my excel sheet then calculate mpg, cost per mile, etc along with all maintenance and costs. I also graph the mpg as it's a good indicator if something is wrong. I've done this with all my vehicles since the early 90's... must be the engineer in me.
Old 03-05-2010, 06:44 PM   #14
Jarhead
Semper Fi Camaro
Jarhead's Avatar
Give the free oil change to someone who can use it. Like a stang owner....
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Oil Capacity LS3 Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 77 04-21-2014 11:19 PM
Save Money on Oil and Oil Filters! 7CAMARO7 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 4 10-07-2009 09:21 PM
3,000 Miles - No "Metal Shavings" - Anyone Else? FNKNSTN 5th Gen Camaro SS LS LT General Discussions 48 10-06-2009 12:46 AM
