Old 03-05-2010, 08:35 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
GM / SLP ZL 575 warranty debate
I know there has been much debate on the slp-zl cars and gm,, as to who is covering the warranty,, i can now verify that gm does not approve of the slp cars and does not recognize them as being covered under gm powertrain warranty, as soon as you bring a slp-zl car into a gm dealer for any powertrain warranty work and gm finds out it is a slp supercharged car they will instantly void all gm powertrain warranty and place a gm warranty block on the vehicle.
seems everyone thinks just because they purchased the vehicle from your gm dealer that you are getting a gm warranty,, not true.
Old 03-05-2010, 08:44 PM   #2
Russell James
Russell James's Avatar
Not really SLP specific, all the tuner cars. Hennessey, Lingenfelter, SLP ... All those tuner/upfitters provide their own warranty. Not sure what the controversy would be about. If you buy one of those it is pretty clear in the literature, and on their websites that the powertrain warranty is now theirs and not GM.
Old 03-05-2010, 08:48 PM   #3
camaro1
camaro1's Avatar
the SLP cars are the only ones you can order and buy right from the GM dealer and people are thinking that Gm and SLP are togething on building these cars and that there is no issues with warranty work.
also no one is told when they buy their SLP car that their gm powertrain warranty will be void.
Old 03-05-2010, 09:32 PM   #4
sykb47l
Drives: 73' VW Bug
Wow that sucks!!!
sykb47l is offline   Reply With Quote
Old 03-05-2010, 09:36 PM   #5
Sheitskees
Drives: 2006 Cobalt SS
Well that's good to know that if you buy the SLP it's not covered by GM's factory warranty. But if it's covered by SLP's then what's the big deal? Shouldn't it be pretty much the same powertrain warranty coverage as GM?
Sheitskees.
Sheitskees is offline   Reply With Quote
Old 03-05-2010, 10:56 PM   #6
Barefooter
Drives: 2010 ZL575
I don't about all the fine print. All I know is that my dealer said it is full warrenty and it's in writing. If GM won't pay then they will.
Barefooter is offline   Reply With Quote
Old 03-05-2010, 11:21 PM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I don't see the big deal here. It is clearly stated as having a 3 year 36,000 power train warranty. Sure it's not as long as the GM power train but I've never had a power train die on me yet. Either way someone else foots the bill.
9/26/09 Took delivery!
Old 03-05-2010, 11:23 PM   #8
Sheitskees
Plus, unless they build these things to fall apart at 36,001, then you should have pretty much the standard ware and tear set it on it. There really shouldn't be more surprises in how the power plant reacts... But there are always those little hiccups.
Sheitskees.
Old 03-06-2010, 02:26 AM   #9
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Shenanigans Lameness and Pisspoor.
THUMPER20X is offline   Reply With Quote
Old 03-06-2010, 07:55 AM   #10
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
So you didn't take the car back into the dealer you bought it from? I don't think that the dealer that sold you the car would void your warranty for the powertrain. Why wouldn't they just call up SLP and fix whatever powertrain issue there was with SLP funding the repair?
cab2g is offline   Reply With Quote
Old 03-06-2010, 08:31 AM   #11
camaro1
camaro1's Avatar
not my car, but yes the car was taken to the dealer where it was purchased, and as soon as gm found out the car was a slp car they said gm never supported the SLP program and that the entire powertrain warranty is void, sure enough a gm vis was ran the next day and yes there was a warranty block on all powertrain
Old 03-06-2010, 08:42 AM   #12
jordanc
jordanc's Avatar
Drives: Cyber Grey Camaro SS
i think the dealer who sold the car should be responsable you know they made money off of it they should take care of all the paper work and fix the car and work out the detailes for the consumer like sending it where ever it needs to be fixed
Red Maggie,Kooks Headers and exhaust K&N intake, Hurst Shifter Mike Noris Tune
jordanc is offline   Reply With Quote
Old 03-06-2010, 08:44 AM   #13
jordanc
jordanc's Avatar
as long as the car was sold new and it was dealer upgrades ^^^^^
Old 03-06-2010, 08:47 AM   #14
Blueclyde
Drives: 2023 ZLE
I don't blame GM. Why should they get stuck holding the warranty paper on a powertrain not design for that kind of flywheel torque? Not sure what SLP does to beef up the drivetrain but I sure would be asking before spending that kind of ching...
Blueclyde is offline   Reply With Quote
Your Warranty Rights The_Blur Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 75 10-19-2012 08:24 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 09:31 AM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 12:37 PM
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 09:25 PM
