Old 03-06-2010, 09:14 AM   #1
AdamCzap
Drives: 18 zl1, 17 sierra denali
installing headers in driveway - which jacks/ramps??
I know this question has been asked before, but I'm wondering if anyone can provide advice for me on this because my car has the factory ground effects and I'm worried about not having enough clearance.
I currently own 2 rhino ramps but not jackstands. Would it be possible to do this job with the rhino ramps? Any specific recommendations for the job?
I have the tools necessary and more or less know my way around down there. (that's what she said)
AdamCzap is offline   Reply With Quote
Old 03-06-2010, 10:40 AM   #2
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300 2015 Z06
It would be real tight if your installing long tube's,I think you better get it jacked up at least 2 feet to get enough clearance.Just be carefull with stands that high
BUMBLEB is offline   Reply With Quote
Old 03-06-2010, 10:49 AM   #3
Russell James
Russell James's Avatar
Your going to want 4 jackstands. Can't go wrong buying jackstands, you will have uses for them the rest of your life. Some of the ones in my garage are over 30 years old.
Do the stuff on top, while the car is low. Then get it up high on jackstands. Keeping it level is much better, so 4.
Then, what I do when working on tall jackstands is put the ramps back under the front tires just in case. I also leave the floor jack under the crossmember with just a hair of weight on it. The weight will be on the jackstands but you've got the jack under there and the ramps, just in case.
I go way over board on safety when under my cars in the driveway, but haven't squished myself yet. And I can work by myself at my own pace without worry.
Old 03-06-2010, 11:23 AM   #4
AdamCzap
thanks Russell! i definitely want to make sure i'm being safe about it!
Old 03-06-2010, 12:05 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
YES, PLEASE BE SAFE, we don't need any FLAT members.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-06-2010, 04:39 PM   #6
fcu678
5Th Gen (Craig)
fcu678's Avatar
Drives: 2014 C7
You shouldn't have any problems clearing the ground effects. We just did mine today but we were up on a rack with it. Plenty of clearance the longest part was adjusting the exhaust tips to center in the openings. We played with that for over an hour but it was worth it.
fcu678 is offline   Reply With Quote
Old 03-06-2010, 07:54 PM   #7
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I got some 2 x 12s and screwed them to the bottom of my rhino ramps. Some guys are using 2 x 10s staggered for oil changes. Just modified that idea a bit. Drove up on those and then used Jack stands for the rear. Plenty of room then. Just use a small step ladder to work underhood. Worked for me by myself.
1977and2010 is offline   Reply With Quote
Old 03-06-2010, 09:18 PM   #8
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
Originally Posted by fcu678 View Post
... We played with that for over an hour but it was worth it.
ditto on the tip adjustments to get it nice.
and the stupid dipstick tube was hard to see where it went back since its so tight near the starter and heatshield.
def want enough room to maneuver under the car without a problem. good luck.
LT1Jeep is offline   Reply With Quote
Old 03-06-2010, 11:23 PM   #9
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Mine was up on ramps, so the tire was maybe 1 foot off the ground, I did it myself, used tie wraps to hold the headers in place while I got out from underneath the car to bolt them up, took me about 3.5 hours
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 03-07-2010, 02:13 AM   #10
AdamCzap
dude, i totally stripped out an O2 sensor today doing this job. luckily i was able to hit up sears store and snag a 3/4" thread cutting tool and cut me a new one!
i can't even believe how awesome it sounds with my noweeds kit. it makes me want to kick my mom in the face!
-adam
Old 03-07-2010, 12:05 PM   #11
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
...... it makes me want to kick my mom in the face!
-adam
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 04-23-2010, 08:33 PM   #12
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Sound clips adam I have kooks long tubes with cats and noweeds all to install this weekend into monday.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 04-23-2010, 09:59 PM   #13
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I changed mine out with long tubes in my garage, each wheel 4 inches off the ground was plenty. http://www.camaro5.com/forums/showthread.php?t=58363
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 04-23-2010, 10:31 PM   #14
n2oSS
n2oSS's Avatar
Drives: 2010 SS2 Camaro
I put on the Dynatech longtubes a couple weeks ago. Warning my way isn't the safest.
First unbolt the flanges on the cats then un bolt headers leaving a bolt in each side to hold while ya get ready to drop. Then me and my buddy got two regular jackstands, used a floor jack and lifted front of car to max height of jackstands. We were able to remove the stock headers at that height.
On installing headers, we first loosely hung cats on new headers so they could swivel. Then had to raise jack above max limit of stands probally another 6 inches. moved headers from bottom of car up, i pushed up while buddy was up top guiding the header. I must say it went back up pretty easy. Next i moved cats into stock exhaust flanges. friend then put gasket on and started two bolts, repeated on next side. Lowered car once we and all tools were clear and tightened it all up.
Took about two hours total and most of that time was trying to remember where we set tools.
Mods:
Dynatech Headers, High flow cats, MSD 8.5 wires, magnaflow bullits, Halltech intake, SCT tuner,
maggie tvs 2300, Jannetty Tune, BMR driveshaft safety loop, Pfadt drop springs, Pfadt rear trailing arms, Pfadt rear tie rod, ACT Twin Disc Clutch, DSS Aluminum Driveshaft.
Appearance Mods:
AAC Concept Sidemarkers, P13W Plasma LED Bulbs, Iforged Classics 20".
Next Mods:
Cam and Fuel System.
n2oSS is offline   Reply With Quote
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
Installing headers using ramps? Camar0wn3d Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 10-18-2009 04:41 PM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
