Old 03-06-2010, 01:47 PM   #1
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Does Ported Throttle Body Help?
Just wondering if a ported throttle body will help with forced induction cars?
Is it worth the hassle of the change out & cost of say $300?
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 03-06-2010, 02:04 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
It will help if you're looking to squeeze every last drop of horsepower out of your car. Like if you were a professional drag racer but for the most part you'll never notice the difference.
*disclaimer, this is only my opinion
Old 03-06-2010, 02:10 PM   #3
d69chris
Florida C5
d69chris's Avatar
If it's $100 bucks and you swap it out yourself, would you do it?
Old 03-06-2010, 04:18 PM   #4
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
I did it once and had problems with part throttle driving and ended up buying a new factory one. Stay with factory throttle! My two cents!
Z_Rocks is offline   Reply With Quote
Old 03-06-2010, 05:15 PM   #5
BlownChevy
Drives: 2015 1SS RS 1LE
I would save your money and put it toward a better proven MOD.
BlownChevy is offline   Reply With Quote
Old 03-06-2010, 07:22 PM   #6
ZYA_LTR
Drives: Waiting to be ordered
From what i have read, and seen on dyno testing, there isn't much gain to be had with the T/B swap on FI... The Blower/Turbo will push the air through just fine. Like above said, you might encounter driveabilty issues on part throttle driving in some rare cases. Now a custom sheet metal intake might see a difference, or going from a old school LS1 intake to a FAST intake, but the newer intakes and such are flowing pretty good. Hell, even the catalytic converters on our cars are so efficient, that the gains seen by removing them are marginal, but the real gain by removing them is the sound level increase.
Forgot to add.....the above info is geared towards centrifugal units that blow through the TB, no units like a roots style that suck through, i have no experience testing those.
ZYA_LTR is offline   Reply With Quote
Old 03-06-2010, 07:24 PM   #7
Ghost of Vincent Price
Banned
Drives: 2010 Camaro
I ported my own on my ls1 and had 0 problems. Its actually pretty easy. I havent got around to doing it for the l99 yet.
Ghost of Vincent Price is offline   Reply With Quote
Old 03-06-2010, 10:17 PM   #8
BlownChevy
The throttle body on the Camaro has a Parabolic bore, this allows a very small percentage of the blade to be exposed during tip in and parking lot driving. Honing out the bore will only makes the vehicle drive worse. GM spent allot of time and money perfecting the 90mm TB that you guys have on your cars, do not throw that out of the window for a "perceived" 3 HP gain. Save your money.
LS1 TB's are different, so please do not confuse the two and make the mistake with your LS3 Throttle Body.
Old 03-07-2010, 04:38 AM   #9
ADM PERFORMANCE
Drives: Anything I want
Yep....LS2 IS DIFFERENT THAN LS3 AS WELL.
Ported throttlebodys do work,re machined throttlebodys(Made larger bore and venturi than stock) can have issues.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 03-07-2010, 11:33 AM   #10
d69chris
Florida C5
d69chris's Avatar
What is difference in ported and remachined?
Old 03-07-2010, 10:12 PM   #11
ADM PERFORMANCE
Correctly ported throttlebody would basically be smoother than stock with the blade shaft smooth down to help flow over it.
Re-machined are generaly made larger,larger butterfly,venturi change...as blown chevy said.
Old 03-08-2010, 08:35 AM   #12
Z_Rocks
Z_Rocks's Avatar
This is what I had done [mentioned in my original post] and messed up my driveability and ended up buying a new one.
Ported throttle body sale matt d. V8 Bolt-Ons & Tunes 3 11-24-2009 12:11 AM
MDinduction- $165.00 Ported throttle body matt d. V8 Bolt-Ons & Tunes 13 11-01-2009 09:28 AM
