Old 03-08-2010, 06:11 PM   #1
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300 2015 Z06
PFADT POLY DIFF BUSHINGS (GEAR WHINING) NOW
Just installed my PFADT rear diff bushings last weekend,Now I am noticing allot of gear whining under very slight load in gear.If you let off gas goes away or if give a Little more gas it will also go away.In 5th and 6th gear light cruise it is allot more noticeable also,It was not their before,the bushings were installed.I was wondering if any one else is having this problem and can I use a different bushing maybe a Little softer?
BUMBLEB is offline   Reply With Quote
Old 03-08-2010, 06:27 PM   #2
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Did you get the differential installed correctly back into position? This almost sounds like it is tilted or cock-eyed. Just enough that it binding? That make sense or am I off in left field?
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-08-2010, 06:33 PM   #3
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Hit up Aaron with Pfadt Racing. He's a member on here.
Old 03-08-2010, 08:21 PM   #4
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Cheers
K
Left Field...The diff will only fit in the correct position. Can't possibly tilt or bind it.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 03-09-2010, 10:51 AM   #5
Moriartii
Moriartii's Avatar
Thanks mtcwby!! Was a guess.
Cheers
K
Old 03-12-2010, 09:01 PM   #6
Petersimov
Drives: 2ss
did u get it fixed
Petersimov is offline   Reply With Quote
Old 03-12-2010, 10:35 PM   #7
IROCanSS
Drives: 89 IROC 350
mine do too.... I thought it was my 4.10s but it does not do it all the time! I talked to my install guy and he said the gears are PERFECT. I am experiencing the EXACT same whine as you, only at certian speeds and not at coast or accelleration, most noticable at 50-60 cruising. hmmmm??? Lets see what the toe bars and trailing arms do... they go on in 2 weeks.
I will be watching this.
Old 03-13-2010, 03:40 PM   #8
baysinger
baysinger
Drives: 2010 IOM M6 SS
If the ring and pinion gear are set too loose or too tight it will whine neither is good. If it were mine I would get it corrected soon. In fact the next time I drove it would be to the shop to have it corrected. If you continue to drive it like this causing improper wear you may never be able to get the noise out. Just My Opinion
baysinger is offline   Reply With Quote
Old 03-13-2010, 04:28 PM   #9
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
This is probably normal noise that is only more noticable now because the lack of insulation that these stiffer bushings provide. Pfadt makes a hell of a product but not everybody is going to enjoy driving a race car everyday and unfortunately this is the give and take relationship with performance parts.
Robert91RS is offline   Reply With Quote
Old 03-13-2010, 04:40 PM   #10
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
The OP never stated he had done a gear swap but that the noise started after installing diff bushings. So no damage to worry about.
Old 03-13-2010, 09:36 PM   #11
IROCanSS
Drives: 89 IROC 350
This is what I am thinking too. I am experiencing the EXACT scenerio as the OP, noise at the same times but my installer tells me my 4.10s gear pattern is perfect. Checked and rechecked so he is not sure why the noise is there and why it is so speratic. If the OP has factory 3.45s still in his car and is exeperienceing the same noise I can only assume it is from the bushings.
Old 03-13-2010, 11:04 PM   #12
Petersimov
Drives: 2ss
who else makes the diff bushings
Old 03-13-2010, 11:27 PM   #13
IROCanSS
Drives: 89 IROC 350
I think BMR might
Old 03-14-2010, 12:34 AM   #14
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
I understand what you are saying,But I can think of several people that are running the pfadt bushings and no noise.I thought about going back to the stock more insulated bushings and trying to stiffen them up by putting round pieces of nylon rod in the gaps,but I tossed the bushings and gm says they are not sold seperatly from the rear diff.
Pfadt Poly Differential Mounts Installed Blue70SS Suspension / Brakes / Chassis 85 06-15-2018 07:35 PM
Wanted Pfadt sway bar bushings kga10734 Suspension / Chassis / Brakes 2 03-06-2010 11:41 PM
Mike Norris Motorsports and Pfadt Race Engineering 5th Gen Differential Poly Mounts Mike Norris Transmission / Driveline 0 01-21-2010 11:03 AM
DIY Pfadt Poly Differential Mounts Blue70SS Camaro DIY & HOW-TO instructions & discussions 0 01-20-2010 12:59 PM
Pfadt Racing Poly Control Arm Bushing Kit PfadtRacing Suspension / Chassis / Brakes 9 12-13-2009 01:38 AM
