Old 03-10-2010, 12:20 AM   #1
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
UPDATED: 2011 Silverado HD Offers Best in Class Diesel Horsepower and Torque
New 2011 Chevrolet Silverado Heavy Duty Trucks Deliver Best-In-Class Diesel Torque And Horsepower
Link to Press Release
o New 6.6L Duramax turbo diesel rated at 397 hp (296 kW) and 765 lb.-ft. of torque (1,037 Nm)
o Segment-best diesel power complemented by up to 11-percent improved highway fuel economy and up to 63-percent reduced NOx emissions
o Up to 680-mile (1,090 km) driving range with Duramax engine in pickups
o Standard small-block 6.0L gas V-8 delivers 360 hp (268 kW)
PONTIAC, Mich. – Chevrolet’s new 2011 Silverado 2500HD and 3500HD pickups deliver the segment’s best diesel power. Their new, optional 6.6L Duramax turbo-diesel V-8 is rated at 397 horsepower (296 kW) at 3,000 rpm and 765 lb.-ft. of torque (1,037 Nm) at 1,600 rpm – an improvement of 32 horsepower (24 kW) and 105 lb.-ft. of torque (142 Nm) over last year’s engine.
“Segment-leading power is great, but it’s not the only thing that makes the new Duramax a winner,” said Gary Arvan, Duramax chief engineer. “We designed the engine to make that power with less fuel and fewer emissions, while also increasing its durability.”
A slightly different version of the 6.6L Duramax is offered in Silverado HD chassis and box-delete models. It is based on the same improved architecture and includes most of the same features as the pickup version, but is engineered to meet federal certification standards for incomplete vehicles, including the incorporation of a robust EGR system. It is rated at 335 horsepower (249 kW) at 3,100 rpm and 685 lb.-ft. of torque (928 Nm) at 1,600 rpm.
Among the 2011 6.6L Duramax turbo diesel’s new and enhanced features are:
* Main bearing profiles changed to enhance oil film thickness
* Oil pump flow increased for more pressure at low speeds
* A revised turbocharger oil circuit for increased pressure at the turbo and faster oil delivery
* Connecting rod pin ends modified to provide increased piston support
* New, higher-strength piston design
* A new 30,000-psi (2,000 bar) piezo-actuated fuel injection system – capable of operating on ASTM grade B20 biodiesel – ensures more precise fuel delivery, improving emission performance
* An EGR cooler bypass reduces high-mileage soot deposits in the cooler and EGR circuit (pickup versions only).
The more powerful 6.6L Duramax is also more fuel-efficient – up to 11-percent greater highway fuel economy than the outgoing model – reduces NOx emissions by up to 63 percent and helps enable greater towing ratings. Silverado 3500HD equipped with a fifth wheel hitch can tow up to 20,000 pounds (9,072 kg). The increased fuel efficiency, combined with a new, 36-gallon (136 L) fuel tank, provides up to 680 miles (1,090 km) of highway driving between fill-ups.
With nearly 1.3 million Duramax diesel engines put into operation since its launch in 2000, no other automaker has as much diesel engine development experience for meeting the demands of the heavy-duty truck customer.
Strong small-block 6.0L V-8
The standard engine in Silverado HD trucks is the Vortec 6.0L small-block V-8, which is enhanced for 2011 with greater idle refinement. It is rated at 360 horsepower (268 kW) at 5,400 rpm and 380 lb.-ft. (515 Nm) at 4,200 rpm in Silverado 2500HD and 3500HD pickup models. In chassis cab and box-delete models, as well as pickups with a GVWR greater than 10,000 pounds, it is rated at 322 horsepower (240 kW) at 4,400 rpm and 380 lb.-ft. (515 Nm) at 4,200 rpm.
Approximately 90 percent of the Vortec 6.0L’s peak torque is available by only 2,000 rpm and excellent fuel economy is enabled by the engine’s low-friction OHV configuration and cam phasing. The state-of-the-art small-block architecture of the Vortec 6.0L – known commonly as the “LS” family – delivers great strength, smoothness and durability.
Whether equipped with the 6.6L Duramax or the small-block 6.0L, all 2011 Silverado models work under the best warranty coverage in America – a five-year/100,000-mile limited powertrain warranty, plus roadside assistance, courtesy transportation and other features that provide assurance that Chevrolet backs its trucks for everything the road offers.
2023 GMC Canyon Elevation
Old 03-10-2010, 12:22 AM   #2
riverrattcom
Drives: 2010 2SS RS SIM
When is the Chevrolet’s new 2011 Silverado 2500HD suppose to be released for sale?
riverrattcom is offline   Reply With Quote
Old 03-10-2010, 12:24 AM   #3
FenwickHockey65
Scheduled for launch this summer. SORP for Regular/Crew Cab models on May 24, Ext. Cab models on July 6.
Old 03-10-2010, 01:31 AM   #4
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
My brother is planning on getting one of these. Hope he does, they are some powerful engines.
a_Username is offline   Reply With Quote
Old 03-10-2010, 09:23 AM   #5
riverrattcom
Any pictures of the 2011 Chevy/GMC out there yet?
Old 03-10-2010, 09:49 AM   #6
Nice
Old 03-10-2010, 10:07 AM   #7
Fenah
Fenah's Avatar
Drives: car
I was expecting a little more bump for HP in the 6.0
Fenah is offline   Reply With Quote
Old 03-10-2010, 10:27 AM   #8
FenwickHockey65
Photography...
Old 03-10-2010, 10:32 AM   #9
WongBob
Dig Race?
Drives: '13 AGM 2SS/RS 1LE
Im thinking of buying one later this year. Need a new work truck....
WongBob is offline   Reply With Quote
Old 03-10-2010, 08:39 PM   #10
riverrattcom
Nice Truck!
Was hoping for a little more design change, looks like they just cleaned the lines up, done some changing on the front bumper and grill. And looks like they made it taller.
Old 03-10-2010, 09:52 PM   #11
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
Looks like a revised grill area, maybe an interior peice here and there. But 765 lb ft of torque?
Scrappy Doo is offline   Reply With Quote
Old 03-10-2010, 10:06 PM   #12
riverrattcom
I wonder if its tall as the Ford.
And can you finally get the 2500 with 20" wheels as an option?
Old 03-10-2010, 10:11 PM   #13
OuSoonersGirl
I need a V-1 BAD!
OuSoonersGirl's Avatar
Drives: 2010 Camaro SS
Man I LOVE Silverados.
OuSoonersGirl is offline   Reply With Quote
Old 05-18-2010, 01:24 AM   #14
FenwickHockey65
UPDATE: Towing rating upped to 21,700 pounds, best in class. Payload rating upped to 6,635 pounds, best in class.
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Horsepower V.S. Torque Milk 1027 Wiki 0 09-15-2009 12:19 AM
horsepower vs torque zebra Dragstrip and Launch Techniques Discussion 35 09-09-2009 09:26 PM
