Old 03-10-2010, 03:16 PM   #1
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
mobil oil filters
has any one here used a mobil1 oil filter on there ss. i changed my oil this weekend and decided to use a mobil oil filter. the filter was tight as i screwed it on (it was not cross threaded). i filled the car up with oil and started it. oil started squirted oil all over the car. i was just wondering if anny one has had any issues with one on a 2010 camaro. i use them on my z28 and never had any problems. and yes i put oil on the seal that seams to be the first question i get form every one
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-10-2010, 03:19 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Could just be a freak filter. I had that happen years ago on my Z28. It scared the crap out of me when I looked in my mirror and saw a cloud of white smoke following me. The filter looked fine when I removed it.
Old 03-10-2010, 03:22 PM   #3
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Yes I use Mobil One oil filters on my 2SS without any issues. I typically put mine on, with oil on the seal, then tighten by hand, then put my end cap filter wrench on it - tightening it 3/4 more of a turn.
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-10-2010, 03:24 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Good filters, use to use em allot till they got hard to find and the selection of filters went down.
Some reason no one carries but a few oil filters anymore, instead of a whole isle full.
2ndgenz28 is offline   Reply With Quote
Old 03-10-2010, 03:32 PM   #5
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
I'm a fan of Purolator, Bosch and Delco. Easy to find and good quality.
brandotron is offline   Reply With Quote
Old 03-13-2010, 02:51 PM   #6
halo8hkk
thx for the responses it must have been a freak thing with that filter.
2000 Z28 = SOLD
IMB Silver Stripes
VIN#44025
Old 03-13-2010, 07:00 PM   #7
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
Always make sure that the rubber gasket comes off with the old filter. If it does not, and you screw the new filter on over it, exactly what you described will happen.
I found that out the hard way...
Iron Lung Jimmy is offline   Reply With Quote
Old 03-13-2010, 07:15 PM   #8
Sherwood SS
Sherwood SS's Avatar
Drives: Black SS/RS
I used one on my last change and it has worked great so far. I wonder what happened with yours?
Black SS/RS - Magnaflow Comp Series, Eibach Suspension, Roto-Fab Intake
Sherwood SS is offline   Reply With Quote
Old 03-13-2010, 07:35 PM   #9
Russell James
Russell James's Avatar
Nothing wrong with the ACDelco filter that was designed for the car. Plus if anything goes wrong while on the road, tow it in to any dealer and get a warranty repair. Show up with an aftermarket filter and get an estimate.
Any other brand and your just spending more money. Plus who know if it was designed for the same micron filtration?
I'll bet if you took two high mileage fleet vehicles, use ACDelco oil filters on one and K & N on the other. At 200,000 miles the only difference would be a lighter wallet by one of the owners.
Old 03-13-2010, 07:43 PM   #10
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
This totally sounds like you left the old seal on the car.. It is easy to do, personal experience. It will not seal with two seals in place, it will do exactly what you described.
Coop 2010 is offline   Reply With Quote
Old 03-13-2010, 08:37 PM   #11
ron10
Drives: 2010 2SS IOM L99
what he said.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Save Money on Oil and Oil Filters! 7CAMARO7 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 4 10-07-2009 09:21 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
