Old 03-15-2010, 10:12 AM   #1
cyber_satan
Drives: Red Dragon
Talking Can you Burn out @ Auto Camaro !
Hi,
I know its the dumbest question ever ! you really cant do a burn out with the Auto can you?
cyber_satan is offline   Reply With Quote
Old 03-15-2010, 10:20 AM   #2
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
I do them all the time with an auto v-6!
2024 Camaro SS convertible
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
philthy is offline   Reply With Quote
Old 03-15-2010, 10:21 AM   #3
cyber_satan
Drives: Red Dragon
how?
So u select manual ! put it in "1"
and put ur foot down on the gas pedal?
Old 03-15-2010, 10:31 AM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Shut off the nannies and try NOT to do one. (Shut off traction control and stabilitrack.)
Old 03-15-2010, 10:36 AM   #5
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Sure you can. Put it in D, shut off tractions control, put one foot on the brake and mash down the gas with the other. It will lock the front wheels up and smoke the rears. In fact, if properly executed, you should almost be able to sit still and smoke the tires as long as you want in an auto where you would have trouble doing the same in a manual (assuming you don't have a separate front brake lever installed).
* DISCLAIMER: I do not personally condone burn outs nor do I take responsibility for the wear on your rear tires after trying the above.
Inspector 17 is offline   Reply With Quote
Old 03-15-2010, 10:37 AM   #6
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Originally Posted by cyber_satan View Post
Hi,
Here's a little one for you:
Old 03-15-2010, 10:39 AM   #7
ron10
Drives: 2010 2SS IOM L99
what is the logic ?
Old 03-15-2010, 10:41 AM   #8
cyber_satan
Drives: Red Dragon
i dont want to to burn outs ! but hey i have a camaro ! just want to try it out some time i was trying to do it yesterday ! first i tried disabling trac control but it wasnt letting me do it properly !
Darth Emma just pointed it out ! that i need to disable stabilitrack !
so i will try that today !
Old 03-15-2010, 10:41 AM   #9
1badSS/RS
1badSS/RS's Avatar
Drives: Rally Yellow Transformers pkg
With very little effort whatsoever.
1badSS/RS is offline   Reply With Quote
Old 03-15-2010, 10:46 AM   #10
myold88
myold88's Avatar
Originally Posted by ron10 View Post
what is the logic ?
There is none.
Old 03-15-2010, 10:48 AM   #11
Inspector 17
I love crepes
That doesn't exactly make sense. Traction control is what keeps the wheels from spinning in straight line acceleration. StabiliTrak is what keeps the rearend of the car from spinning out in corners. See Wikipedia's definitions:
"A traction control system (TCS)...is designed to prevent loss of traction of the driven road wheels, and therefore maintain the control of the vehicle when excessive throttle is applied by the driver and the condition of the road surface (due to varying factors) is unable to cope with the torque applied.
StabiliTrak uses sensors to detect the difference between the steering wheel angle and the direction you're actually turning and depending on the situation, applies quick, precise force to the appropriate brakes to help the driver control the vehicle’s direction to help keep it on course."
Turning the traction control off should allow you to spin the wheels. Trust me. BTW, once you do it one time, you will want to do it again. Let me just warn you now.
Old 03-15-2010, 11:01 AM   #12
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Press and hold the traction control button for 7 seconds.
But please, make sure there are no vehicles, trees, signs, or other random obstacles within 200 feet of you when you decide to have your fun
Old 03-15-2010, 11:15 AM   #13
pour some bleach on the ground
Old 03-15-2010, 11:17 AM   #14
cyber_satan
Drives: Red Dragon
yoo ! ur right ! or may be i was expecting better response ! i unno
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
Chevrolet's Camaro Authority at Camaro at Virginia Motor Trend Int Auto Show MTAutoShows USA - Southeast 0 02-12-2010 05:42 PM
