![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
WATER IN MUFFLERS
what is up with all the water in the stock mufflers ? every post i read where someone has installed a new system,they report that the stock mufflers were full of water,when they pulled them off.for those of us that are keeping the stock system, what can we do to take care of this problem ? can you drill a hole in the muffler ? or what is your suggestion? if drilling a hole would drain the water,where would you put it ?
![]() Drives: 2010 2SS/RS, 2006 2500 Silverado Join Date: Dec 2009
"Watch your thoughts, for they become words. Choose your words, for they become actions. Understand your actions, for they become habits. Study your habits, for they will become your character. Develop your character, for it becomes your destiny." |
#3 | |
![]() Drives: 2010 Camaro 2LT Rally Yellow Join Date: Jan 2010
![]() Drives: Too Little time to drive.... Join Date: Oct 2009
On my 2LT/RS I have weep holes near the lowest part of the muffler from the factory. I've also noticed that it does sling water and black soot along with it when I'm driving because I can see the stain on the mufflers.
![]() Drives: 2016 1LT Garnet Red Join Date: Dec 2008
Condensation is all it is, do not worry about. GM had been putting drain hole in the mufflers for at least 25 years. It keeps them from rusting out.
2011 1LT/RS Summit White A6
#6 |
![]() Drives: 2010 camaro 2SSRS, Maggie SC, Kooks Join Date: Sep 2009
I think its more than condensation, had mine removed the other day and the water sloshes inside, both in mufflers and resonator and they only have 2500 miles and the car has only seen rain once. sounds like its quite a bit in there.
#7 | |
Rolling along...
When I still had the stock exhaust, I noticed that any water that I accidentally sprayed on/in/around the tips usually didn't come back out.
#8 | |
#9 | |
perhaps, but it was only washed once by me. Now that I changed out the exhaust, its not an issue
#10 |
Semper Fi Camaro
Drives: 2010 1SS/RS Aqua Blue LS3 Gauge PKG Join Date: Jan 2010
The thing is that the condensation builds up over time, as you probably know it is not from one day.. I'm not sure the weep hole is doing it's job correctly. It should allow the build up to run out. As an earlier post indicated I also see the soot comming out of the weep hole and staining the bottom of the muffler. The hole appears to be in a good location, but I'm wondering if it is collecting in a chamber that does not have a passage that allows the condensation to flow out of it. Would need to see a cutaway of a stock muffler to determine this though.
Anyone out there have pics of a ss muffler cutaway ???(LS3/M6 in my case).
#11 |
Emerald Coast Camaros
Drives: 2010 2SS Rally Yellow Join Date: Feb 2009
That's what it is. When washing the car the water gets in there and stays. I had my mufflers removed and I had lots of water in mine. A the guy said it was from spraying the car in the tailpipes. Which I wasn't tring too just wanted the soap off.
#12 |
![]() Drives: 2011 2SS Red Jewel Tintcoat Vert Join Date: Mar 2010
I had the same issue with the driver side muffler when I went to do the SLP muffler delete. It was full of water (heavy as hell). The weep hole was clogged. I used an ice pick to un-clog it and water came streaming out. The passenger side muffler was just fine.
I would recommend anyone with stock mufflers check to make sure the weep holes are not clogged. With normal condensation, there will alwalys be a small amount of water that comes out of the mufflers. |
#13 | |
![]() Drives: 2010 1SS CAMARO/GBA/M6- sold. Join Date: Oct 2009
i am going to see if mine are clogged or at least make sure they are not.
![]() 1SS @ home. 12/14/2009 ![]() |
#14 | |
The mufflers already have a weep hole in them. You exhaust system has a 100k warranty |
| What song are you listening to right now | Muscle Master | Off-topic Discussions | 6760 | 11-08-2025 01:54 AM |
| Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 123 | 02-05-2024 09:55 PM |
| MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) | themossman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 07-12-2010 09:56 AM |
| Car Washing.................... | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 03-08-2010 06:48 PM |
| How to dry your Black Camaro without water spots | gzartman | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 55 | 10-27-2009 03:46 AM |
