Old 03-19-2010, 09:17 AM   #1
1baer
Drives: Camaro 2SS / RS
Noise from Air Vents
i have a probelm with a noise from the ventilation system.
turning the vent to position 2 and up produces a somehow clattering, crispy sound with a high frequency that is not very loud but annoying.
it is NOT comming from the glove box area.
i really don't know what produces the noise. it sounds like the fan would touch somewhere or a bearing is defect or something like that. it's quite difficult to describe. it does not disappear when i change the air output to floor or windshield or to recirculation. it only alters the volume of the noise a bit.
interrestingly, turning the temperature from cold to hot changes also the intensitiy of the noise. it is loudest near the hot position and then gets clearly more quiet in the hottest position.
perhaps the fan is the problem, but i'm really not sure.
any help would be great.
1baer is offline   Reply With Quote
Old 03-19-2010, 10:29 AM   #2
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
Is this with the vanes closed? I found that if they are open just slightly, I hear a noise. Fully closed or open a bit more brings the sound.
TonyNo is offline   Reply With Quote
Old 03-19-2010, 10:49 AM   #3
1baer
it doesn't make a difference if the flaps are open or closed. if the middle ones are closed or nearly closed, there is a whistling. but that's not what i'am talking about.
Old 03-22-2010, 03:52 PM   #4
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
there was a thread about this a long time ago.. I have the same issue... it's like a high pitch squealing noise. . .
Didn't see any fix on this issue though.
franknbeans is offline   Reply With Quote
Old 03-23-2010, 12:36 AM   #5
thematrix007
Drives: 2010 SS 1
I have the same problem ss1 6-speed mrg date 10/17/10
One thing is when i pop the hood the sound is comeing from the motor like
a vac leak but it's not. i hear it in the cab as well. when i rev the motor it
changes pitch it's like a audio system with out a ground loop isolator but
it ant comeing from the speakers!! could it be the main motor drive pulley
balancer rubbing the belt the wrong way?? this is the case in older cars.
I don't know does any one?? it sounds like friction like a high pitch air whistl. ya and they did not mess up and supercharge it LOL dumb asses
this is a real problem that needs addressed. thanks for any help L.J.R
thematrix007 is offline   Reply With Quote
Old 03-24-2010, 12:32 PM   #6
Big_T
Big_T's Avatar
Drives: 2010 Camaro
I had started a thread on this last year, I had the fan motor replaced, but that did not fix it. I am sure this is a problem with the vent tubes/line they used, and I do not see any chance this will be fixed. My suggestion is what I do. CRANK UP THE VOLUME!!
Big_T is offline   Reply With Quote
Old 03-24-2010, 12:35 PM   #7
the upcoming
the upcoming's Avatar
Drives: 10'2SS/RS,94'toyoda,02'vette
yes i just recently started hearing a "chattering" coming from maybe the vents r somewhere under the hood
im always driving so i cant check it out
the upcoming is offline   Reply With Quote
Old 03-31-2010, 06:26 AM   #8
1baer
my dealer took a look at the car and the fan motor and said that the noise is definitely not coming from the fan motor. like Big_T, he said that it's probably coming from the tubes / airflow and that perhaps this is producing some sort of vibrations or that the airflow itself is producing the noise. he also did not see a way to fix it. he would have to take everything apart and find the spot where the noise is coming from. but this procedure makes no sense to me at the moment.
Old 03-31-2010, 06:29 AM   #9
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
Blow her... and by her i mean car... and by blow i mean a maggie...
then you wil hear a useful whistle !
AlSuwaidi is offline   Reply With Quote
Old 12-13-2010, 12:10 AM   #10
tuningvelocity
Drives: 2011 Chevy Camaro
re:
I have a 2011 1LT and I've had this noise for the past 2 months and I bought this car 3 months ago. It has finally gotten to me and I'm taking it to the dealer this week, but in the meantime has anyone found a solution??
Thanks
tuningvelocity is offline   Reply With Quote
Old 12-13-2010, 08:41 PM   #11
knuckle dragger
knuckle dragger's Avatar
Drives: Black 2SS/RS and White ZL1
started in my car today.
When asking someone to think outside the box....you must first determine what size of box they are working with!
knuckle dragger is offline   Reply With Quote
Old 12-14-2010, 10:14 AM   #12
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
If you are hearing what I do, I think it is a part number sticker flapping inside one of the ducts
f5journal is offline   Reply With Quote
Old 12-14-2010, 02:44 PM   #13
live2well
Drives: 2010 VR 2SS/RS A6
That makes sense. I have the same issue. Thanks dude.
Intelligence plus character that is the goal of true education.
BrianC. :flag2:
live2well is offline   Reply With Quote
Old 12-15-2010, 08:57 AM   #14
Blessed
Blessed's Avatar
Drives: 2010 2SS/RS Red Camaro
Mine started yesterday. I think it is the fan that acutally blows the air. Mine is super noticable with the fan speed set one click above off and heat all the way maxed. I can turn the fan speed up and notice a pitch difference. If I turned the fan speed full blast don't notice it.
I am just guessing but I think it has to do with the cold weather gumming up the grease or oil that is on the fan. Like I said this is just a guess.
Blessed is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 03:46 PM
Lets Talk About Extended Warranties for our 2010 Camaro's from the Dealership a Sec.. Black LS3 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 39 03-21-2010 12:38 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
Air Intake Information for GM's 3.6L V6 Airaid Filters Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 91 10-27-2009 08:26 AM
