Old 03-21-2010, 02:25 PM   #1
JCL-2SS
JCL-2SS's Avatar
Drives: 2010 2SS Imperial Blue
Blue Smoke
I have a 2010 2SS Automatic with L-99 engine with 1000 miles on it, this week i started the car and blue smoke puffed out the back, as i pulled out i got half way on the car to pull into traffic and more blue smoke came out, has not happened since then. should i bring back to the dealer, anybody else have this issue? I have been babying the car since i got it and have not really driven it hard.
on a side note im also getting a lot of vibration and low speed and very light gas pedal, is that normal and part of the variable valve timing using only 4 cyl., i notice the vibration goes away if i speed up.
Thanks,
Charlie
JCL-2SS is offline   Reply With Quote
Old 03-21-2010, 02:36 PM   #2
Blizzard
Searching for the truth
Blizzard's Avatar
Drives: 85 K-10, 13 1LE
Had the car been sitting for a long time when u got the blue smoke? and no vibration should be normal.
2013 1LE 1SS RS TPW 4/29
Blizzard is offline   Reply With Quote
Old 03-21-2010, 03:12 PM   #3
3BVert
3BVert's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by JCL-2SS View Post
... on a side note im also getting a lot of vibration and low speed and very light gas pedal, is that normal and part of the variable valve timing using only 4 cyl., i notice the vibration goes away if i speed up. ...
The dealer told me it's "normal". It's caused by AFM. I've since taken matters into my own hands and tuned AFM out and this problem went away. Since you have potential powertrain issues. I can't recommend that you do the same since applying a tune could void your powertrain warranty. Using tap shift helps to mask the problem since you can keep your RPMs up. Of course that will cause you to get less MPG which was the point of AFM in the first place.
Good luck.
2SS/RS Red Jewel Tintcoat
6-Speed Automatic
3BVert is offline   Reply With Quote
Old 03-21-2010, 08:12 PM   #4
balthazar
balthazar's Avatar
Drives: Black 2SS/RS w/Ground Effects
Working with computers I saw "blue smoke" and thought this was headed somewhere else entirely.
On topic. After having sat for, say a day or so, sometimes even overnight, it's not unusual to see small puffs of "smoke".
If it's SMOKING...there is a problem. If it's just a few little puffs...I wouldn't worry. Definitely think twice before modding until you get a solid answer from someone who sees it.
balthazar is offline   Reply With Quote
Old 03-21-2010, 08:51 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Blue smoke is caused by the engine burning oil. If it's that much of a worry to you buy a catch can but burning a little is normal seeing how the engines are designed. You can check V8 section for more info as there are dozens on threads on catch cans but basically oil gets into the intake and gets burned causing the blue smoke.
Old 03-22-2010, 01:59 AM   #6
JCL-2SS
JCL-2SS's Avatar
so the car only sat for 1 hour in a lot, when i came back out and started it puffed lots of blue smoke, then right after i pulled out onto a busy street and had to give it some gas due to oncoming traffic and it smoked again, clearing up by the tie i got to 40 or 50 mph. the second time i had the blue puff car was at my house overnight. Im gonna bring it back to dealer this week, i have the advantage of not filling out the survey yet.
Is there any hang out spot on Long Island NY for meetups or local clubs?
Old 03-22-2010, 09:13 AM   #7
definitely bring it back to your dealer
Old 03-22-2010, 03:21 PM   #8
DangerZL1
Drives: 2023 Black ZL1 Auto
You might want to look at this thread about exhaust smoke:
http://www.camaro5.com/forums/showth...ighlight=smoke
DangerZL1 is offline   Reply With Quote
Old 03-22-2010, 05:17 PM   #9
JCL-2SS
JCL-2SS's Avatar
Thank DangerouSS, this looks like it fits the exact issue im having!!! bringing it to the dealer this week!! i didnt fill out the survey yet so i got some ammo between that and the bulletin when i go in.
Old 03-23-2010, 12:00 PM   #10
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
My car smokes a lot when it is cold outside or when it idles for a long time, but this is not blue smoke, it is white smoke from condensation. All car used to do this before catalytic converters. Are you sure it was blue smoke? It maybe normal condensation smoke.
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 03-23-2010, 03:15 PM   #11
JCL-2SS
JCL-2SS's Avatar
ok went to the dealer today, it was 100% blue smoke by the way, they wouldn't take the car in without an appointment, the CS manager didnt seem to show much care about my issue. I'm very upset about this. The general manager wasn't there so he will get an ear full next time i go there ( friday). i told them to at least to check the oil and it was 1/2 quart low, which to me is significant considering oil is the blood of a motor, surely if one of us was bleeding we wouldnt want to wait 3 days to stop it.the car has only 1200 miles and 1 month old. more to come on friday.
Old 03-23-2010, 03:26 PM   #12
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
1/2 a quart low ain't bad at all.
THE EVIL TW1N is offline   Reply With Quote
Old 03-24-2010, 08:39 AM   #13
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
i am having the same problem...
i ordered a RevXtreme catch can to solve the problem!
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 03-24-2010, 08:51 AM   #14
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
1/2 quart low for an engine that is still being broken in isn't bad at all.
Raise our voices!! We need a 2nd Blue in 2011!! SS22 5th Gen Camaro SS LS LT General Discussions 51 01-04-2010 10:14 PM
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 02:44 PM
Blue SS/ can change order yet. coilman Cosmetics and Lighting Modification Discussions 18 12-17-2008 07:56 AM
Poll: Soooo whose switching their color to blue? SimC33 Camaro Price | Ordering | Tracking | Dealers Discussions 17 11-10-2008 01:49 PM
Will there be anything Blue for the interior??? JeanBond21 Cosmetics and Lighting Modification Discussions 4 09-30-2008 01:53 AM
