![]() Drives: '91 Z28, '11 2SS L99 Join Date: Feb 2010
Test drive and now two questions
So I was test driving a new Camaro lately: Black 2SS/RS, inferno-orange interior and stripes. I really like the looks of the car, absolutely awesome. It felt pretty good driving it.
I have two Camaros here that I’m interested to buy: First one is an early production car with 6-speed manual w/o parkassist Second one is a newer one with parkassist and the automatic trans The rest is almost identical I think. Now are there any pros and cons for one or the other production wise? And if I would go for the automatic car: can the shift paddles moved to the same side? (I want both on the left because I have no right hand) |
Sorry about the hand, but if you have no right handthen wouldnt you have no choice but to go automatic and stick to automatic driving and not use paddles? Im guessing as the need for paddles on one side is there then you cant really use a stick either..
Ide go with auto in your position.. |
Oh wow....umm...definitely go with Auto. GM is so far refusing to make a right hand car because it is not cost effective.
Good luck with the car!
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
Get the Automatic
#5 | |
BOD 5/28/09 #13485
Drives: 2010 Camaro 2LT RS Join Date: Jan 2009
I think you would need to have a custom steering wheel made to have both shift paddles on one side and I am sure this would be expensive. If you get the auto I think you would be stuck with just leaving it in auto mode and it sounds to me like it is important to you to be able to shift it. I hope this helps.
#6 | |
![]() Drives: 1LT/RS Yellow/Black Join Date: Mar 2010
#7 |
![]() Drives: 2LT/BB 3.6 V6 6-M Jun'09 #A9100242 Join Date: Jul 2009
Anything is possible once you have executed the skills of driving a manual with/without a prosthetic hand. BTW, Sorry about the hand. If you are up for the manual - I don’t see why not. Have you tried driving a manual before? They are fun cars to drive especially the M6.
P.S. At my job we now have new hybrid diesel trucks that don’t have shifters for the tranny and with a touch of a finger is all that is needed. The shifting panel is located on the dashboard close to the steering wheel. It’s very cool and I will take a picture to show.
#8 |
Thanks for the replies.
I was born like that, so I'm pretty much used to it ;-) Actually I'm driving a 4th Gen Z28 with the manual transmission so no problem with shifting. I think I only will get the automatic if there is a possibility to relocate the right paddle to the left side. About the other question: are there other interesting features on the newer production cars beside the park assistant feature? |
#9 |
It’s hard to say anything about the 2011 features right now. I tried talking to many GM sources and they have no clue or can’t say for policy reasons. I’m hoping to hear something about it on the car show this coming April.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
With the limited rear visibility I personal am very happy to have them on my car. The backup sensors are the only added feature between the early and later production numbers. On the early production cars they had the GM chicklets at the bottom of the fender and the "Performance Division" plaque under the hood. Both of those are cosmetic things.
Build Journal ![]() |
#11 |
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Silverado 4x4 Z71 Join Date: Dec 2009
If it were me,I would call GM Customer Service and explain your situation. They have the Mobility/customization for handicapped drivers. Just throwing that out for food for thought. If you can't find a link or # to call I would be more than happy to help locate the info for you.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71. |
#13 |
![]() Drives: Malibu, g6, camaro Join Date: Sep 2009
It would be quite the mod, but I don't see any reason tap-shift couldn't be moved to the left side. It's all electronic and I would think that the right kind of buttons shouldn't be that hard to find. I would guess buttons would be the easiest due to space considerations on the wheel, but you may be able to find a suitable momentary rocker switch that would have a more sporty feel.
Like posted above, be sure to check with GM on this, they may have something already made for this. If not, they should be able to find out what the switch requirements would be. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
automatic.
