Old 03-23-2010, 12:30 AM   #1
jnm2003
jnm2003's Avatar
Drives: O2 GMC & 2010 camaro SS IBM 6M
Recommend all to do differential fluid change!!!
I changed my differential fluid last weekend and im almost at 3000 miles. WOW it was like liquid metal coming out of the drain plug!! If you opened up a can of primer grey paint it would look identical to my fluid. I have had two other friends with 2010 camaros drain theirs and it was the same. one had 1500 miles and the other had around 2500. The tip of the drain plug had so much build up of metal and grime that i touched it with my fingers and taped two fingers together and it was like i had chewing gum between my fingers!!
RECOMMEND TO ALL WHO HAVENT CHANGED THEIR FLUID NO MATTER 1200 OR 10000 MILES TO CHANGE THEIR DIFFERENTIAL FLUID!!!!
Anyone did a tranny fluid change and had any issues? Im thinking about changing mine and if anyone has any fluid come out like my diff than im going to jump on changing my tranny fluid.
2010 camaro SS/RS Manual IBM.
NEW TIME 12.24 @ 114 mph. -[B] street tires, Hurst short throw, Halltech yellow jacket intake, AR long tube 1 7/8 headers, and a tune.
12.82 @ 110 MPH 1.92 60ft ALMOST Bone Stock ONLY MOD IS Borla mufflers.
jnm2003 is offline   Reply With Quote
Old 03-23-2010, 12:46 AM   #2
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
Had the dealer change oil, tranny, and diff at 1800 miles. Looked at me like I was crazy, but it was worth the piece of mind. After I was done, he said it was a good idea but didn't elaborate... Hmm...
I know, I'm lazy but work trips got in the way of proper maintenance. I at least did verify they changed everything by the drips and wipe marks on everything.
gotroost is offline   Reply With Quote
Old 03-23-2010, 08:19 AM   #3
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Good info, thanks. What did you fill it with? Royal Purple?
Maybe they're putting some sort of break-in additive in at the factory.
Maybe I'll plan to do this at 1500 miles.
Old 03-23-2010, 09:05 AM   #4
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
How much did that set you back?
Moorepheus is offline   Reply With Quote
Old 03-23-2010, 09:15 AM   #5
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
I changed both my manual trans and rear end fluid at 6200 miles. The trans fluid was real clean with just a little build up on the magnetic plug. The rear end made me wish I changed it at 500 miles because it was so dirty. You could see the flakes of metal in the fluid and both the drain and fill magnetic plugs had tons of build up. I used Redline 75w90 in the rear end with no extra friction modifier needed and Redline 75w90NS in the trans.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 03-23-2010, 10:09 AM   #6
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I changed my diff at 1080 miles and it looked just like the OP described. I put redline 75w90 back in. I have the manual trans to do but havent found the time yet to do it.
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-23-2010, 10:41 AM   #7
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
All in all good advice. I would try and hold out to at least 3k before changing the diff though. A posi diff and new gear set are going to create some metal fleck so if you will wait until they have time to fully seat you won't trash your expensive new fluid.
Robert91RS is offline   Reply With Quote
Old 03-23-2010, 10:50 AM   #8
Moorepheus
Ok, I just looked in the manual, and this is what is says to do (no where does it say to change the manual transmission fluid, weird!
First Engine Oil Change After
Every 40 000 km/25,000 Miles
Fuel system inspection for
damage or leaks.
Exhaust system inspection for
loose or damaged components.
Every 80 000 km/50,000 Miles
Engine air cleaner filter
replacement. See
Engine Air
Cleaner/Filter on page 9-16
Automatic transmission fluid
change (severe service) for
vehicles mainly driven in heavy
city traffic in hot weather, in hilly
or mountainous terrain, when
frequently towing a trailer, or used
for taxi, police, or delivery service.
See
Automatic Transmission
Fluid on page 9-14
Rear axle fluid change (severe
service) for vehicles mainly driven
in hilly or mountainous terrain,
when frequently towing a
trailer, used for high speed or
competitive driving, or used for
See
Rear Axle on page 9-30.
Every 160 000 km/100,000 Miles
change (normal service).
See
Fluid on page 9-14
Rear axle fluid change (normal
service). See
Rear Axle on
page 9-30
Spark plug replacement.
An Emission Control Service.
Every 240 000 km/150,000 Miles
Engine cooling system drain,
flush, and refill, cooling system
and cap pressure check,
and cleaning of outside of
radiator and air conditioning
condenser (or every 5 years,
whichever occurs first). See
Cooling System on page 9-17
Engine accessory drive belt
inspection for fraying, excessive
cracks, or obvious damage
and replacement, if needed.
Old 03-23-2010, 10:54 AM   #9
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
I did my first oil change and differential change at 500 miles. I drained both through a coffee filter and holy shit! The main reason I did that was from what a lot of people say about LS engines and all the metal flakes within the first couple thousand miles. I am glad however that GM used magnetic plugs to help catch the metal flakes but unfortunatley it will all catch a small amount. I want to do the tranmission as soon as the weather breaks. I went with Royal Purple in the oil and differential, I am thinking the same for the manual transmission. Any suggestions?
FFPM73
FFPM73 is offline   Reply With Quote
Old 03-23-2010, 11:13 AM   #10
ron10
Drives: 2010 2SS IOM L99
great info.i guess i had better have mine changed.THANKS
Old 03-23-2010, 12:02 PM   #11
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I have done the engine with the stock Mobil 1 oil and M6 fluid too. The rear end is next.
The manual tranny really likes the Mobil 1 synthetic ATF I put in there. It is the multi-car formula based on Dexron 3. Trust me - it IS better than what is in there now. You will feel the difference when you shift. Nice easy improvement for maybe $7 per quart x 4 quarts = $28.
The rear end will be getting the GM fluid and additive.
-Mark.
Old 03-23-2010, 07:32 PM   #12
flyby
Drives: 2010 Silver SS
Make sure when you do the tranny fluid change you use the correct type. 6cylinder uses gear oil v8 uses trans fluid. check your book measure twice, cut once.
flyby is offline   Reply With Quote
Old 03-23-2010, 07:39 PM   #13
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
where is the plug for the diff fluid? and what kinda fluid does gm use? if i use a different kinda fluid would it void the warrenty?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 03-23-2010, 08:46 PM   #14
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
You used 75w90 in the manual transmission? Good luck with that. Not even close to a recommended tranny lube for the Tremec 6060.
Diff drain and fill plugs are on the drivers side. My Chevy dealer put in Royal Purple Gear Max. No need for any additives. Won't void warranty.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
Keep My 2SS Going Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 02-19-2009 11:50 AM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
