Old 03-24-2010, 09:02 AM   #1
NoFatChx
Drives: 1LT RS Rally Yellow
Tap Shift When to Use
I've got an automatic with tap shift and I was wondering when using the tap shift when am I supposed to shift up.
NoFatChx is offline   Reply With Quote
Old 03-24-2010, 09:08 AM   #2
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Well, that's kinda like asking "when do I shift up with my manual transmission". You just know when to shift, it comes without thinking after a while. It's entirely up to you, you have a rev limiter.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 03-24-2010, 09:18 AM   #3
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
its for fun, its not that great for drag racing because it does not shift immediatly you can accidently hit the rev limiter and make it bog and lose time. when in tap shift mode you can shift when you want, i upshift at about 5000 rpm so by the time it shifts you will be just under the rev limiter rpm. for drag racing put it in M that is sport mode but dont touch the tap shift it will shift faster and it shifts just before the rev limiter kicks in. tap shift is good for road racing so you can be in the right rpm's in the powerband for fast exits out of the turns. with a tune torque managment tuned out downshifting will slow the car assisting the brakes to slow you quicker into tight turns.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
tap shift
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
Tap Shift & Manual Stick bumblebee123 5th Gen Camaro SS LS LT General Discussions 40 11-14-2010 06:55 PM
Did Camaro (automatic) reviewers use tap shift ? trudawg660 5th Gen Camaro SS LS LT General Discussions 30 11-09-2010 07:55 PM
Tap Shift on the Stick ttss V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 12-09-2009 07:44 AM
Tap Shift not standard? MB2010CC 5th Gen Camaro SS LS LT General Discussions 8 11-09-2008 11:30 PM
