Old 03-25-2010, 06:05 PM   #1
asmith10
Drives: Camaro 2LT/RS IBM
Injector Cleaner
How often do yall run a bottle of injector cleaner? I have almost 7k miles and I have yet to run a bottle through.
asmith10 is offline   Reply With Quote
Old 03-25-2010, 06:07 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Never have on my cars...probably a good idea though. Just started running Techron by Chevron fuel injector cleaning on the bike - over 17K miles on her.
Interested in hearing opinions though
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 03-25-2010, 07:13 PM   #3
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
I run an injector cleaner of some type (Seafoam, Techron, Shell V-Power or Berryman B-12 Chemtool) through the gas tank at each oil change. I'll buy the stuff when it is on sale and stockpile it for later.
Not running the fuel tank low (I generally refill to full at 1/2 tank) due to the amount of moisture drawn into the tank as it vents keeps moisture out of the fuel system. All of the gas where I live (Central Florida) has up to 10% ethenol, which helps "dry the gas".
I only change oil every 6 months using either Mobil 1 or Valvoline Synpower (usually bought at Wal-Mart because of price and they fact that the sell it in 5 QT. jugs) in the recommended weights. Filters are the same (watch for sales on the high end filters or buy in case lots from a wholesaler).
In 6 months our family cars only average 3 to 8 thousand miles, at most. I have never experienced any oil related problems or excess wear on any of my vehicles using these intervals.
I just had the valve cover off of my Son's 2002 Honda Civic EX with 110 K miles last week, while doing a PM on the timing belt and the engine looked new with no sludge, residue or noticeable wear. The '99 Corvette I traded in on my new SW 1LT M6 was the same, with no build up or sludge at all at 109 K miles.
I believe most of the benefits we see with the synthetics of lower friction (less heat generated) and better lubricity at startup are more evident on fuel injected motors due to less oil dilution than motors with carburetors.
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 03-26-2010, 07:13 AM   #4
JSkibisky
Drives: 2010 1LT/RS
... I usually do it at every oil change... every 3K in my case.
JSkibisky is offline   Reply With Quote
Old 03-26-2010, 09:10 AM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I've never used injector cleaner and never had any injector issues. I've driven fuel injected cars for 30 years. I do change fuel filters according to maintenance schedule.
Old 03-26-2010, 09:39 AM   #6
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
i usually put Lucas Upper Cylinder Lubricant w/ Injector Cleaner in my old truck every 12000 miles.
for the Camaro i will just do it every oil change.
you really do not need it as often as every 3000 miles. if you buy gas that is a "top tier fuel" you do not need it but every tire rotation, not every oil change
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
