Old 03-27-2010, 12:31 PM   #1
Supercharged SS
Drives: 2010 Camaro
Air pressure on drag radials?
Just looking to get a starting point with pressure on my 18" M and H drag radials. I have never used them so any help would be greatly appreciated. I've been told to start around 16 psi and then after the burnout they should be about 18 psi. Sound right? They are on an A6 that makes 545 / 555 at the wheels. Im hoping they work.
Thanks
Old 03-27-2010, 02:42 PM   #2
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Mine are the M&H 275/45r18 and i run 18 psi. It runs a 11.66 in the qtr. Also an a6 but with a YANK ss3200 converter That was nov 09 times. Since then i have put in a mast motorsports stage 1 cam and valvetrain upgrades so i'll be going to the track in the next couple weeks.
silverfox is offline   Reply With Quote
Old 03-30-2010, 11:15 PM   #3
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2021 C8 Z51
I ran 20 psi in my ZL550 on 20" Nitto 555r. seemed to hook up pretty good. Also A6 car said to have 550HP at crank have not had on dyno yet.
lewylew is offline   Reply With Quote
Old 03-30-2010, 11:17 PM   #4
Supercharged SS
Drives: 2010 Camaro
I ended up going with 17.5 psi and it hooked everytime. 1.6 60's. Next time I will try some different pressures.
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8853 06-13-2022 08:45 PM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
Fastlane Pipeline Cold Air Intake Fastlane V8 Bolt-Ons & Tunes 24 01-12-2010 10:35 AM
Drag Radials a_Username Wheels and Tires Talk Sponsored by The Tire Rack 19 10-07-2009 07:44 PM
18" Drag Radials Merc Wheels and Tires Talk Sponsored by The Tire Rack 4 09-25-2009 01:33 PM
