![]() Drives: 2010 2SS/RS IOM M6 Join Date: Sep 2007
Richmond 4.10 install Q
I would have a shop do the install for me. The question is, do I need to buy the full installation kit along with the gears, or would a shop be able to do it without the kit?
Thanks
Placed order: 02.25.2010
Took delivery: 04.06.2010 Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links |
I would buy the full installation kit.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
You will need an install kit...
Whether your shop feels they need the full kit or the half kit is up to them. |
Thanks guys! Any idea what a shop would charge for labor on this job?
If you are just dropping off the car and having them do it, you would be looking around $500, but dont forget you also need to have it tuned to get the correct readings on the speedo etc... and to take full advantage of the gear change.
#6 |
So on an M6, I'd need a tune after this mod, or would I be ok with just the Hypertech calibrator ?
I guess 4.10's would probably void my powertrain warranty anyway, right?
#7 |
![]() Drives: 2010 2SSRS m6 Join Date: Jul 2009
My shop did mine for 550. No install kit needed. They had to use a couple .010. Shims that were lying around the shop and a new crush sleve from gm. Runs perfect with no noise at any rpm on accel or decell. That's 509 for the gears and 550 =1059. Best 1000 bucks I've spent so far. What a difference
#8 | |
#9 |
![]() ![]() Drives: 2010 LSX Shootout World AM Finalist Join Date: Sep 2009
get the install kit
we charge 500 for install |
#10 |
you dont need the whole install kit. It is a wasted 259.00 bucks.. You should not need any of the bearings. Just a few shims and a crush sleeve at most. My contact pattern and back lash were almost perfect with no shims at all. WE tweaked it a little with a couple .01 shims on the carrier to get everything perfect.
#11 |
#12 | |
So this is falsely advertised?
#13 |
Thanks, mark_p. How are you enjoying the change?
#14 |
all i can say is let the good times roll......
![]() I have managed to take two mustang guys for a ride that were not ready for raw pin you to your seat power this car has now... Hit second gear with the 305 nittos and 4:10's and hold the he** on. It is crazy fast.. |
| Richmond Gears 3.73 4.10 | SupremacyCustoms | Transmission / Driveline | 12 | 05-20-2010 11:04 PM |
| Richmond 4.10 impression after first 60 miles. | IROCanSS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 67 | 05-18-2010 09:31 AM |
| Richmond Gears V8 and V6 - Group Buy | ZZcamaro | Transmission / Driveline | 175 | 04-30-2010 01:29 AM |
| When is the 4.10 Richmond Gears coming out for the V6??? | GearLube | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 04-26-2010 06:22 PM |
| NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 11:36 AM |
