Old 03-31-2010, 12:03 AM   #1
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
Exclamation 1SS DRL disabling, but keep Auto on @ night?
I want to have my 1ss headlights only come on at night..... I already installed HIDs to it and it is a PITA shutting them off every time I start the car during the day. Any ideas?
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 03-31-2010, 10:26 AM   #2
EAkrish
Scout Sniping
EAkrish's Avatar
no one finds this annoying? I don't want DRLs anymore. How do I disable them?
Eric
Old 03-31-2010, 12:22 PM   #3
FASST 1
FASST 1's Avatar
Drives: Black 1SS
FASST 1 is offline   Reply With Quote
Old 03-31-2010, 12:27 PM   #4
Ronn
Ronn's Avatar
Drives: 2010 Camaro
It's probably gonna be a fuse that goes to a relay for the drl's. If I had a schematic I'd probably be able to tell you heh. Good luck.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 03-31-2010, 12:38 PM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I would think you could just disconnect the lights and tape over the ends to keep water out. Maybe that's a bad thing to do, but I don't know enough about these things.
Old 03-31-2010, 04:00 PM   #6
GQ4Life
Drives: 2010 Camaro SS LS3
i was think that.. just unplug foglights..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 03-31-2010, 04:40 PM   #7
mtbikerinme83
mtbikerinme83's Avatar
Drives: 2010 2SS/RS LS3-M6
He has the 1ss without the rs package, he installed HIDs into the stock halogen housings. When you do this, your HIDs will be on during the day because the low voltage for the day time running lamps (which is the headlights, not the fogs on a non RS car) will turn on the HIDs. I have a 2SS without the RS package and have been looking into how to deal with the DRL and would also like to find a way to disable them. There should be a relay somewhere for them that you would just have to remove the relay. I haven't tried to find it yet.
Currently:
2010 CGM 2SS/RS GFX LS3-M6, 3.91 1LE diff, Kooks LTH w/ cats, Borla Touring axel back, CAI intake with race scoop, and custom dyno tune
Previously:
2010 IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 03-31-2010, 10:55 PM   #8
EAkrish
Scout Sniping
EAkrish's Avatar
me neither, my buddy has a 2006 gto and his drl were the headlights also. he pulled the fuse and poof, they were gone. and with this method he has retained the auto on at night function. THIS IS WHAT I WANT TO ACCOMPLISH!!!
Eric
Old 04-01-2010, 06:53 AM   #9
FASST 1
FASST 1's Avatar
Drives: Black 1SS
Thats two of us!
Old 04-01-2010, 08:49 AM   #10
marley.
OCD
marley.'s Avatar
Drives: 2014 2SS/RS 1LE
make that three of us
marley. is offline   Reply With Quote
Old 04-02-2010, 08:21 AM   #11
EAkrish
Scout Sniping
EAkrish's Avatar
Anyone?
Eric
Old 04-02-2010, 01:34 PM   #12
marley.
OCD
marley.'s Avatar
Actually took my car to the dealer this morning and had them hook it up to their computer to disable the DRLs and they couldnt figure it out either. This sucks. BFXenon sent me a relay kit that was supposed to fix it but all it does is make a horrible buzzing sound til my HIDs flicker and then go out.
Old 04-12-2010, 02:29 AM   #13
EAkrish
Scout Sniping
EAkrish's Avatar
this is bs..... all the other cars with drls can just pull a fuse and we can't do SH#!
Eric
Old 04-12-2010, 02:57 AM   #14
BUMBLE B
BUMBLE B's Avatar
Drives: 99 Z28 CONV and 2010 SS
tHESE NEW 2010'S HAVE CURRENT SENSING CIRCUITRY WHICH WILL GIVE YOU AN ON DASH NASTY-GRAM IF ABULB IS BURNT OPEN, OR ANY OTHER "REGULAR" CURRENT LEVEL TO A LIGHT IS OFF FROM SPEC'S. tHIS IS TO "HELP " YOU IDENTIFY A BURNT OUT LIGHT or excesssive power draw,, BUT ALSO PREVENTS YOU FROM ADDING AUXILLIARY INTERIOR LIGHTS TO CERTAIN FUSED LINES. THE CIGARETTE LIGHTER LINE IS NOT MONITORED (FUSED ONLY) AS THE CAR EXPECTS VARIABLE LOADS THERE. Don't believe me?...just disconnect a tail light or turn signal lamp, and an in dash display will tell you which lamp is drawing no power (due to an open filiment...it assumes) so that you are aware of a needed bulb...and also to protect GM from a lawsuit. Lots of those today!!. These 2010's have current monitoring for just about anything that draws power, and will allert the driver is something is drawing too much power or too little power. Add interior LED lights to the interior lighting fused line, and you'll get an error message. unplug a light bulb, and you'll get a "replace bulb" advisory message. These is a whole lot of computer monitoring covering the entire electrical system of it. More work ($$$) for GoodWrench guys to do to the hapless owners of these.
BUMBLE B is offline   Reply With Quote
2006 TRAVERSE CITY AUTO CONFERENCE KILLER74Z28 Off-topic Discussions 2 09-18-2010 09:45 AM
Disabling Daytime Running Light (DRL) buddylok Canada 7 10-07-2009 08:09 AM
Production Camaro at which autoshow dcamaro 5th Gen Camaro SS LS LT General Discussions 31 02-02-2008 11:38 AM
