Tampa Gulf Coast Family
Drives: 1977 Z28, 2SSRS 2010 M6 Join Date: Sep 2009
My clutch fluid reservoir
I found the fluid reservoir at my local junkyard for $5, it came with the bracket. It is from a 1992 Honda accord. It was much more difficult to find one that would work than I thought it would be. Just drilled a couple holes and used stainless self tapping screws, rerouted the clutch fluid line, filled it up, and capped the opening on the brake master and called it done. What you guys think?
VETT 4 5
Drives: Yellow 1SS/RS w/ Clutch Join Date: Nov 2009
How does the actuator (from the pedal) connect to the new master cylinder ? I understand the slave on the clutch itself would just attach via the same line, but unsure how the actuator attached to the existing combo master cylinder would attach to the new remote master reservoir.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Join Date: Jul 2009
The part he just added connects to the pedal actuator. There is another seperate line from the pedal actuator to the slave cylinder at the trans. |
What he said. It is just a reservoir. Seperates the clutch and brake fluids. It should have been like that from the factory.
#5 | |
#6 | |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
If only we could find caps that are made of vinyl or butyl that wouldn't weather.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#7 |
![]() Drives: O2 GMC & 2010 camaro SS IBM 6M Join Date: Sep 2009
I plan on doing my clutch fluid reservoir as soon as I get a hold of one that will work for it!! Thanks for the info about the honda civic reservoir!!
I have a question tho about mine.. Ive been having problems with my clutch sticking to the floor and it not fully disengaging quick enough to allow descent shifts from 1st to second at high RPMS. I put super dot 4 fluid in it and its not nearly as bad as it was. But tonight i went to some street gatherings and ran 3 times against a friends car. Car 95% cooled down before my first race. 3 burnouts, 3 races. Well the clutch stuck to the floor on the second pass i made. After all 3 races and I get back home and lift the hood and see some drops of fluid around the top of the stock reservoir around the cap. couple more around underneath small splatter drops in random places. The reservoir was really warm also. Is my clutch having problems bc the cap maybe isnt sealing all the way to the stock reservoir?.. and would this be my problem when sometimes my clutch doesnt fully disengage (notch feelings while shifting) even with daily driving. or is it bc its still boiling the fluid after burnouts and then racing.. since im using the brakes which use the clutch fluid which will warm it up and then racing also will. I still probably havnt got all the stock fluid out bc ive done a flush two seperate times so far with 4 bottles of super dot 4 total. (expensive). also i used the rangeracceleration technique and cleaned the gasket on the cap each time. so there most definitely is still some stock fluid in the lines bc i didnt bleed it all out or make enough flushes yet. Or is there another problem that would cause too much pressure in the lines to spew fluid through the cap even if it has a good seal? Could the cap be causing most of this and if so when i put the new separate reservoir should have a better sealing cap to not have this problem. Or is it another internal problem that the reservoir would help but sill not fix it and im still in this same situation.
2010 camaro SS/RS Manual IBM. NEW TIME 12.24 @ 114 mph. -[B] street tires, Hurst short throw, Halltech yellow jacket intake, AR long tube 1 7/8 headers, and a tune. 12.82 @ 110 MPH 1.92 60ft ALMOST Bone Stock ONLY MOD IS Borla mufflers. |
#8 |
Wow that was a tough read. Unfortunately I don't have an answer for you. I remember there was talk on here about leaking reservoir caps. I think there was even a TSB for it. Don't know what ever happened with that. I haven't experienced the sticking clutch yet, I have had the brakes do some weird things after some repeated hard launches and hard stops during autocrossing. That was my main reason for separating the fluids. That and I just don't think anything good can come from mixing the two other than GM saving a few bucks.
#9 | |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
http://www.mcmaster.com/#vinyl-tube-caps/=6hl5d2
#10 | ||
#11 |
Dog Is My Copilot
Yeah, that's one catch about McMaster-Carr...sometimes the quantities are over-the-top! They really do have everything, though!
#12 |
![]() Drives: 2011 Camaro SS LS3 Join Date: Jan 2012
Wow! Thank you for this information! I'm starting my hunt for my 1992 Honda Accord fluid reservoir right now...
I really appreciate you guys that are willing to share your experience and knowledge with others. It's very cool. Sam |
#13 |
![]() Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
Nice install,
Guys, keep in mind you can use just about any remote resevoir for this. This one from wilwood is about 20 bucks. To mount it in the same place as the OP mounted his would only require that you make a simple bracket. http://www.wilwood.com/MasterCylinde...emno=260-11098 |
#14 | |
![]() ![]() Drives: Camaro SS Join Date: Mar 2010
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
| Do you think that the car needs a separate Clutch Fluid reservoir | 2SSRS@Gen5diy | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 621 | 08-18-2019 02:38 PM |
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 10:17 PM |
| Seperate clutch reservoir | FFPM73 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 07-22-2010 12:09 AM |
| Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid | Embalmer | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 09-11-2009 10:52 AM |
| Adding a Clutch Reservoir to Isolate it from Brake System | mtcwby | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 08-22-2009 05:02 PM |
