04-03-2010, 12:29 AM | #1 |
Drives: 2010 Camaro Join Date: Mar 2010
Tail Light Wiring - Afterburner Design Help
I'm working on an afterburner kit and I'm trying to figure out how I'm gonna wire it up. Would be great if i had just a blank plug but...
Anyone know what wire is what on the tail lamps duh black is probably ground pink - ? yellow w/black - ? I know one should be brakes and the other should be running lights. |
04-03-2010, 12:36 AM | #2 |
Drives: ... Join Date: Apr 2009
Are you sure on those colors, or I am mis-reading your question.
Mine are.., • Black= Ground • Brown= Parking Lights • Green= Turn Signal |
04-03-2010, 12:36 AM | #3 |
Ok I found that the socket is a wedge type but not sure what kind of led bulb I need. I want it only to come on with the brakes, I'm gonna run the running lights separate.
Any help?? |
04-03-2010, 12:36 AM | #4 |
do you have SS or LT or RS
04-03-2010, 12:41 AM | #5 |
see this could be a huge problem having different colors here's a pic of mine
04-03-2010, 12:42 AM | #6 |
Would the brakes and turn signal be the same one??
I assume so because they are brighter... |
04-03-2010, 12:49 AM | #7 |
Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
try checking the service manual that just came out?
04-03-2010, 12:50 AM | #8 |
have a link to that manual? is it available online?
04-03-2010, 01:31 PM | #9 |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
You have to buy the manual.
10-02-2020, 04:15 PM | #10 |
LEXi is Sassy and Classy
Drives: 2012 Camaro 2LT RS Boston Acoustic Join Date: Mar 2014
daytime running is most often middle, and outter cable is turn and ground in opposite ends.
10-02-2020, 05:56 PM | #11 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
10-09-2020, 03:04 PM | #12 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
Similar Threads | ||||
Tail Light Mod Question | Fredman_Vice | Cosmetics and Lighting Modification Discussions | 13 | 09-21-2010 04:28 PM |
2010 Chevrolet Camaro makes finalist list for 2010 World Car Design of the Year | Tran | 5th Gen Camaro SS LS LT General Discussions | 37 | 02-17-2010 04:22 PM |
Stock Chrome Tail Light Rings | GJG | Cosmetics and Lighting Modification Discussions | 3 | 06-07-2009 08:38 AM |
Headlight and Tail Light Covers coming soon! | Bewenched | Cosmetics and Lighting Modification Discussions | 8 | 05-18-2009 10:20 AM |
