Old 04-03-2010, 08:19 AM   #1
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
Cleaning Microfiber Towels Question
I'm washing my microfiber towel because I can't buy them all the time.
Also, it would be a waist.
I can't keep track of which towels where used where.
If I use a microfiber towels on the wheels and wash them in the washing machine and dry it in the dryer, are they safe to use on the rest of the car again????
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 04-03-2010, 08:59 AM   #2
AntzV
AntzV's Avatar
Drives: blacked out 2010 Camaro
Yea they should be good just when you dry them DO NOT put in a dryer sheet with them
AntzV is offline   Reply With Quote
Old 04-03-2010, 09:12 AM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
u sholuld get this cleaner called microfiber restore, not a good idea to put in dryer, and theres also a cleaner called apc? its a degreaser theat u ca put in there to
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-03-2010, 10:06 AM   #4
NoUCantDriveIt
Drives: 2SS RS M6 CGM/Black Rally
I picked up a pack of towels for just the tires, and another for the lower panels. The different colours makes it easy to keep track of what towel was used where.
NoUCantDriveIt is offline   Reply With Quote
Old 04-03-2010, 10:11 AM   #5
Rich1
Rich1's Avatar
Drives: 2023 ZL1 Camaro Hot Red
Don't wash them with regular towels either because they will get little pieces of the towel all over them...
Rich1 is offline   Reply With Quote
Old 04-03-2010, 02:07 PM   #6
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Here's a decent thread on proper care of microfibers...
2LTRS is offline   Reply With Quote
Old 04-03-2010, 02:52 PM   #7
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
How to Wash Microfiber Towels
First off, you only want to wash them in COLD water. DO NOT use a lot of soap. My towels never get very dirty or greasy because they are only used to wipe polish or wax from the car, thus I can use a gentle detergent like Woolite. You don't want to use the hash detergents like the stuff you use on your regular clothing. If your towels are a little dirtier than normal, let them soak in the washing machine overnight. Simply add the proper amount of Woolite to the washer, add the towels and fill the washer to the proper level. Use the gentle cycle to wash these towels. Allow the wash cycle to begin for 1 minute so that the Woolite has a chance to mix with the towels and then shut the washer down. Let it sit for as long as necessary (overnight if that's what you need, shorter times for towels not as bad), and then start the washer back up later.
DO NOT use any fabric softener of any kind! Do not use too much Woolite! Read the bottle, a little goes a long way. If 1x is good, 2x is worse in this case. Also NEVER. EVER, EVER wash these towels with any other article of clothing, especially bath towels and wash clothes. That will ruin them too.
After the wash, DO NOT DRY THEM IN A DRYER USING HIGH HEAT!!! (if you do, you may as well use them to check the oil because they are useless at that point). I don't use a dryer at all. I allow them to air dry. String up a clothes line in your garage or outside somewhere and buy some clothes pins (if you can find some, that's some old school equipment right there!). If fabric sheets are used with these towels, it will destroy them. That will cause them to start scratching the crap out of your car. Drying them in the dryer with too much heat will do the same thing, that why I tell guys never to machine dry them.
If you follow these rules, your towels will keep the consistency and softness that they had from day one. If you allow your wives or girlfriends to do this, trust me, they will screw them up unless they have read this. Don't assume that they know how to do this and don't let them tell you that they know what they are doing when it comes to microfiber. They do not own, nor have they probably ever owned a piece of material like this so they will not be aware of these requirements. Test them before you hand them over and see if they get it right. I guarantee they won't.
One thing that can be done for lint in your new microfiber towels is to wash them, and then run them in the dryer with no heat. That will fluff them and remove the lint.
I just had a funny thought. I would love to see the look on some of your wives faces when you ask for some Woolite.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 11:00 PM
Engine Cleaning With Pictures Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 05-02-2010 12:00 AM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Towels, Applicators, Mitts, Etc..., Tecca Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 22 06-29-2009 03:52 PM
Best Cleaning Supplies GoldFire Cosmetics and Lighting Modification Discussions 52 02-06-2009 12:50 PM
