Old 04-03-2010, 11:41 AM   #1
flyby
Drives: 2010 Silver SS
Bleeding Brakes
Can someone who has the service manuals tell me if there is anything "special" about bleeding the brakes on an ss, like tools needed that are outside the norm.
flyby is offline   Reply With Quote
Old 04-03-2010, 09:43 PM   #2
flyby
so I guess no one has bled their brakes???
Old 04-04-2010, 12:30 AM   #3
jrpxxii
jrpxxii's Avatar
no special tools needed. couple wrenches and allen wrench and go for it. you can open the bleeders and let them bleed out by gravity if you wish. takes longer but works fine. i used a vaccum pump to do mine as it was quick and painless.
Old 04-05-2010, 12:07 AM   #4
Wesman
Wesman's Avatar
Drives: Trans Am
Since the SS uses Brembo 4 piston calipers, there are two bleeder screws on each caliper.
Per Brembo, start with the inboard bleeder, then do the outboard bleeder of each caliper in order to remove all air from the system.
Wesman is offline   Reply With Quote
Old 04-06-2010, 11:48 AM   #5
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Is there a bleeder for the anti-lock valve?
Beauwulf is offline   Reply With Quote
Old 04-06-2010, 12:04 PM   #6
thekid96
Drives: Z06, 69 Camaro
Nope. If you get air that far in you will need a Tech2 to open and close the ABS valves while bleeding.
thekid96 is offline   Reply With Quote
Old 04-06-2010, 01:13 PM   #7
Beauwulf
Beauwulf's Avatar
Guess I'll just need to be quick when I xhange the lines!
Old 04-06-2010, 03:03 PM   #8
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
After changing the calipers you just need to start bleeding them from the inside bleeder screw on the right rear caliper first, then the outside bleeder then do the same to the left rear ,next to the right front next, then to the left front(drivers side of car being left).
The best way is to have some one in the car with the key off to push the brake peddle to the floor softly while you have 1 bleeder screw open at a time.When your helper gets the peddle to the floor close the bleeder then have them release the peddle and repeat until both bleeders on all four calipers are bleed.Don't open the abs system or pump the peddel as this can cause problems with air in the sysyem.Then you will need a tech 2 to auto bleed the system.This is the best way we have found if you don't have a vacumn bleeder.Gravity bleeding will also work ,but some times will still leave a little air.DON'T let the master cylinder run out of fluid.
Bruce@raymondsperformance is offline   Reply With Quote
Old 04-06-2010, 07:47 PM   #9
thekid96
They don't bleed much fluid once the soft line is disconnected. Take the rubber cap from the caliper bleeder valve and pop it on the hard line to stop it from draining while you swap the lines. Make sure you rap the calipers with a soft mallet when you are bleeding to knock and air bubble free in the caliper.
Old 04-06-2010, 10:26 PM   #10
Beauwulf
Beauwulf's Avatar
I think I have it covered... 35 years as an aircraft mechanic and being a former AMA Pro rider.... was just wondering if the valve had a bleeder. Thanks for the advice though... good stuff!
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 584 10-14-2021 10:33 AM
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
Bleeding Brakes flyby Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 04-03-2010 08:40 AM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 08:23 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
