Old 04-03-2010, 01:21 PM   #1
55Designs
Drives: 2010
TPMS Trouble after installing 3 Piece Custom Wheels.
I had to strap the OEM TPMS Sensor to the barrel of the wheels using stainless strapping bands. I strapped them very close to the actual valve stem in the rim. I 3M Taped them down then with a dremel i made a recess so the strap can lock the sensor in place. I didnt butcher the sensor I basically ground down the plastic loop where the screw goes into the rubber stem.
Once the wheels were on the TPMS seemed to work without any reset or learn process. All 4 wheels had different PSI.
After some hard driving it went into malfunction.
I cant even reset the system I cant get the drivers side front tire to even sound the horn.
Do I need to go to the dealer or is there anything else I should try like disconnecting the battery then trying?
55Designs is offline   Reply With Quote
Old 04-05-2010, 01:13 AM   #2
55Designs
Drives: 2010
Nobody with custom wheels can chime in here for me?
Old 04-05-2010, 01:21 AM   #3
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I had a damaged wheel so I bought a new one. At first I couldnt make the first horn, then realized that I had to take a lot of air of the wheel to make it sound.
Hope it helps
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 04-05-2010, 08:45 AM   #4
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Go to a tire shop with a TPMS activation tool. It broadcasts a signal through the sidewall (sometimes tread) to activate the sensor. Also, it is important to note that most sensors use the valvestem as an antenna. Did you leave the valvestems in place, inside?
Fquick.com/NineBall
Old 04-05-2010, 05:22 PM   #5
Nine Ball
Nine Ball's Avatar
Definitely no antenna there. Doh!
Fquick.com/NineBall
Old 04-05-2010, 09:12 PM   #6
iconz wheels
Drives: 2010 Camaro SS - 2007 C6 Corvette
Send a message via AIM to iconz wheels Send a message via MSN to iconz wheels
TPMS Bracket Adapter
Strapping is an old method, we manufactured adapter brackets that would have integrated with your valve stem....
iconz wheels is offline   Reply With Quote
Old 04-06-2010, 07:35 AM   #7
55Designs
Drives: 2010
I didnt want the barrel drilled for the adaptor nor did I plan to keep the TPMS active while racing.
Il figure out a solution. With the Step Lip on all of these new rims out there the valve stem is at the wrong angle and the sensor can get damaged with mounting a tire.
Lighter wheels = much faster? 1_2Many Wheels and Tires Talk Sponsored by The Tire Rack 41 01-31-2011 12:28 AM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 03:59 PM
Having trouble with pics of chrome wheels on a Yellow car..... Rickerbucks Wheels and Tires Talk Sponsored by The Tire Rack 5 04-03-2010 02:08 AM
SCT Xcal 3 w/ Custom Tunes now available!!! Meister@Torq V8 Bolt-Ons & Tunes 17 12-24-2009 06:02 PM
AFTERMARKET WHEELS AND TPMS dnr427 Wheels and Tires Talk Sponsored by The Tire Rack 6 07-10-2009 12:35 AM
