Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Great Lakes
Old 04-07-2010, 05:00 AM   #1
mikeSS
mikeSS's Avatar
Drives: 2015 c7
looking for shop or someone who can help me install my headers MI
i have some headers i need help installing, i am looking for a shop or maybe another camaro owner or someone that can give me a hand to install this.
i do not have the right knowledge/ resources to do it my self
if you are a shop plz let me know how much this would cost me..
thanks
Old 04-07-2010, 06:09 AM   #2
4SD FED
4SD FED's Avatar
Drives: 2010 rs/ss camaro
Call Eric at VRE (586) 741-0158 they can get it done for you...
4SD FED is offline   Reply With Quote
Old 04-07-2010, 03:25 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ok will do... thanks
Old 04-07-2010, 09:44 PM   #4
oville-rider
oville-rider's Avatar
Drives: 2010 Camaro Summit White 2SS/RS
What brand headers did you get and did you go short or long? Aftermarket exhaust? Just wondering what difficulties might occur and how it will sound after installed? Thinking of going this route. Like to know how it goes?
oville-rider is offline   Reply With Quote
Old 04-07-2010, 10:50 PM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
well i didnt want to blow a lot of money on headers, so i got JBA shorty headers... i already have on my car the GMMP axle back exhaust, and K&N CAI.. so i will post a video within the next 2 weeks with the headers
Old 04-08-2010, 07:37 AM   #6
Russell James
Russell James's Avatar
This is one of the easiest cars to put headers on. You just need 4 tall jack stands. I did LT's on mine by myself with the jackstands set at about 22" tall. A helper would have been nice. But all I did since I was by myself was used boxes. I stacked up boxes below the OE cats/manifolds. Unbolted them from the heads. Then dove underneath, kicked the boxes out and lowered it out.
Put the headers up the same way. Set them up in there on boxes, then went up top and bolted them to the heads.
I took the spark plugs out. If your by yourself can be pretty easy to knock into a plug and break it, so I just took mine out.
Couple other tips.
Pay attention to where the dip stick tube goes before you put the headers on. Get your line of sight figured out of exactly where it sticks in while the headers are off. Because once they are on, it can be tricky to see that spot again. But if you know exactly where to look with a light shining down through the ABS brake lines, and which header pipe to look under, you will just barely be able to see the hole and slip it in there.
Drivers side. Pop the steering shaft off. Very easy, just one pinch bolt, and then it pushes up and lays up out of the way. The trick to getting it back on is to put a screw in the crack to spread it back open. That bugger fought me for a bit until I had an idea to put a small screw in the split line to open it back up a bit before sliding it back on.
The funniest part of the whole job, aside from the fire up rumble, is the dipstick tube bolt. A big ass bolt holding on this little dip stick tube. I guess they don't want that thing falling off.
Old 04-09-2010, 08:42 AM   #7
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Call Dave or Andy at Livernois Motorsports, they will price you very well with a service backed guarantee, you will also enjoy of on the top facility's in the country.
You can reach them a 313-561-5500
Good luck
IPS Brandon is offline   Reply With Quote
Old 04-09-2010, 09:00 PM   #8
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
Call Joe at Stenod Performance in Troy.
http://www.stenodperformance.com/main.html
He did my header install and dyno tune.
http://www.camaro5.com/forums/showthread.php?t=62200
Alfie
alfie43 is offline   Reply With Quote
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
SNEAK PEAK! 2010 camaro RS V6 gains 33HP and torque with install of BBK headers! brothersperformance.com Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 138 02-21-2011 04:27 PM
Pacesetter Headers: Prices a wallet can love!!! bijanmaleki V8 Bolt-Ons & Tunes 20 02-06-2010 12:55 PM
